Old 12-11-2012, 05:20 PM   #1
72c10projectc
72c10projectc's Avatar
damaged vin plate
Well while digging through my truck I noticed the vin plate is damaged severely. The upper part of it where the rivets are is broken what do I do?
72c10projectc is offline   Reply With Quote
Old 12-12-2012, 05:03 AM   #2
SS Tim
SS Tim's Avatar
Re: damaged vin plate
So, You have a damaged cab VIN plate.
Your cab VIN does not match the frame VIN.
http://67-72chevytrucks.com/vboard/s...d.php?t=555876
Your frame is not the same series as the cab.
http://67-72chevytrucks.com/vboard/s...d.php?t=555880
Sounds like you have an issue here. These questions are really all the same thread/issue. Has the truck been titled in your name? Has it had a VIN verification? Before you do anything with this truck get the paperwork and the truck correct to a point where it will pass a roadside traffic stop. Here in California the title is to frame VIN.
If you go ahead with this remember it will not be a true C/20 truck with a C/10 frame and or suspension. The C/20 frame is heavier.
SS Tim is offline   Reply With Quote
Old 12-12-2012, 08:13 AM   #3
mygmctruck
Interesting , I actually have lost the vin tag from my cab and can not locate anything on the frame . I went to our dmv and they told me when the truck is all done , they will come and inspect it, and retag it. They said as long as I have the original title they will do this with any issues.
mygmctruck is offline   Reply With Quote
