Old 12-11-2012, 10:30 PM   #1
72c10projectc
72c10projectc's Avatar
what to do
Well I found out my cab is a 70 c20 cab. And my frame is a 1971 c10 frame. With a 69 bed haha ok it came with a straight six. What would I need to do to the suspension to get it up to a c20
72c10projectc is offline   Reply With Quote
Old 12-11-2012, 10:37 PM   #2
71swb4x4
71swb4x4's Avatar
Re: what to do
Why do you want to get it to the C20 status? Hauling a lot in the bed? Towing a lot?
Did you check the VIN on the frame? How did you figure out is was a 71 C10?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-11-2012, 10:40 PM   #3
jocko
jocko's Avatar
Re: what to do
a whole new suspension. But seriously, 71swb4x4 is spot on - what do you need?
I'm curious how you confirmed also - via frame VIN?
If you need a C20 for real, your easiest course of action is to sell wha tyou have (as a C10) and buy a C20 - or - truy to locate a C20 rolling chassis and swap it over. Doing it suspension piece by suspension piece still won't net you a C20 frame.
Old 12-11-2012, 10:55 PM   #4
72c10projectc
Re: what to do
Well unless someone did a swap it has 5 lug axles and spindles and disk brakes and the partial vin said it was a 71
Old 12-11-2012, 11:16 PM   #5
jocko
jocko's Avatar
Re: what to do
if you want to post your cab vin and your frame vin, you would get LOTS of detailed info here (you can leave off the last numbers that are just the sequential production number).
Am assuming your frame VIN starts CS141... and your cab VIN starts C(?)240..?
(?) is for what the original cab was paired with - E for V8/S for I6
I can sense your frustration. This is a buyer beware, dog eat dog market out there unfortunately - I feel for ya learning this stuff after the fact, can only imagine how frustrated you are.
Old 12-11-2012, 11:27 PM   #6
72c10projectc
Re: what to do
Its not really frustrating but confusing the cab vin is cs240b the frame is 1b64 something
Old 12-11-2012, 11:46 PM   #7
71swb4x4
71swb4x4's Avatar
Re: what to do
So what are your intentions with the truck? When you have a clean slate that will determine what to put there. These trucks aren't rare, converting it back to a C20 just because there is a C20 logo on the fender will not increase the value of the truck.
If your goal is to haul some lumber from the lumber yard once in a while for home projects, heavier springs will do everything you need them to do. You may not even need to do that.
If you are pulling a 10,000 pound trailer you will be looking at the full monty, larger rearend/brakes/springs, heavier front end/springs/brakes.
Old 12-12-2012, 12:46 AM   #8
72c10projectc
Re: what to do
I want it to sit a little lower and I was looking to do a BBC and maybe tow a small camper
Old 12-12-2012, 01:05 AM   #9
jocko
jocko's Avatar
Re: what to do
in that case - if you don't care that you have a bit of a cab/frame mis-match, a C10 (frame) can easily handle the big block (they came with them too) and tow a small camper. Perhaps just some heavy duty shocks, sway bars, upgraded HD/lower springs, etc and you're set.
Old 12-12-2012, 01:10 AM   #10
dan42
dan42's Avatar
Re: what to do
Lots of people have mutts. No worries, you should be able to make it work with a little effort.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 12-12-2012, 12:05 PM   #11
Shyguy
Junior Member
Shyguy's Avatar
Re: what to do
My truck is one of those mutts and as close as I can tell it is made up of parts from at least 9 different years, I guess it could be called a "Johnny Cash Special", named after one of his songs, lol. It is a '67 swb C-20 stepper. One of the most noticable things is it has a '62 GMC tailgate.
That is one of the things I like about these trucks, many parts are interchangeable.
I guess my point is fix up your truck the way you like it.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
