Old 12-12-2012, 12:45 AM   #1
chevymotocross
chevymotocross's Avatar
Can only fill new tank halfway
I had to replace the 16 gallon tank on my 87 for the 2nd time in 5 years. Ever since the install I can't get fuel in the tank past 8 gallons! I have double checked the filler neck and vent hose for any kinks or twists. Everything seems good.
This happens at any gas station. The old tank never had this issue. I have tried filling it slowly, nozzle at various angles. Nothing! What gives!?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 12-12-2012, 03:26 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Can only fill new tank halfway
Is your gauge reading true empty?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-12-2012, 09:13 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
are you sure vent and return are to the correct fittings?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-12-2012, 11:13 AM   #4
chevymotocross
Yes, on the sending unit the vent hose is significantly smaller than the supply/return piping.
As for the gauge that is a good question. Anyway to test this? I think the only way to know for sure is to fill the tank, pop the filler neck off, and stick a piece of wood or something in the tank to confirm if it is full or not.
Old 12-12-2012, 02:27 PM   #5
68_Step
Can you get to the sending unit easily to remove it easily? A multimeter can tell you if the sending unit is bad. On mine it was a 90ohm sending unit and should read 0 to 90 (full), mine was reading 20 to 110.
68_Step is offline   Reply With Quote
Old 12-12-2012, 04:05 PM   #6
1981Stepside
1981Stepside's Avatar
If you have the aux. tank, run it dry, swap to the other tank to get to a gas station and then see how much it takes to fill.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
