12-12-2012, 01:00 AM | #1 |
Nice Farm Truck
I dig the apparent originality of this truck; even the Patriotic scheme is Kool.
And of course the V-6! http://siouxcity.craigslist.org/cto/3421460174.html Are those battery boxes or steps on the ...ermmm...steps?
MusicMan70 1961 GMC Suburban |
12-12-2012, 05:35 AM | #2 |
1961 crewcab
Re: Nice Farm Truck
thats pretty cool, I wonder if it has always been garaged like that?
If so that could be an incredible original unrestored find...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
12-12-2012, 06:50 AM | #3 |
Re: Nice Farm Truck
dual tandem!! Thats pretty cool!!
68 Short step!! |
12-12-2012, 07:43 AM | #4 |
Re: Nice Farm Truck
Interesting how the cab seems to have a completely different cowl from the regular cab....does the LCF Chevy use the same style? I don't think that cab would transplant to a pickup?
Also, says it has a tag axle, which is different from a tandem axle......one of those axles must lift up and down.......and no driver, no differential, like a true tandem would have, it's only designed to carry load. most of those worked by air, but that says electric over hydraulic....never seen one before. Judging by the overspray on the tire, it hasn't been driven much since a repaint |
12-12-2012, 09:16 AM | #5 |
Re: Nice Farm Truck
I like the cowl extensions. They seem to carry out the door lines. Wonder if they'd look good on a c-10/c-30?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-12-2012, 09:59 AM | #6 |
Re: Nice Farm Truck
No. They wouldn't carry the body line from the door into the hood. The reason these taper off the way they do is because that line is not carried into the hood like on the C-series trucks.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
12-12-2012, 05:38 PM | #7 | ||
1961 crewcab
Re: Nice Farm Truck
cowl is the same, it is just the cowl extentions that end, and taper in. chevy also did the lcf with the regular hood, just shorter. those cabs would require some modification, as the foot well is different to make room for the tire.
12-12-2012, 11:28 PM | #8 |
Re: Nice Farm Truck
I nabbed a 409 out of a LCF 65 similar to the yellow one.
I've only seen 2of the W cabs with the sloped nose.... Did a double take... I like them because there different, but they kinda looked pieced together Posted via Mobile Device |
