Old 12-12-2012, 01:06 AM   #1
72chevynoob
duramax in a '69?
How hard would this be? I found a rolled durax in the area for $3500 complete, minus transfer case, and I am wondering if someone that knows a little about vehicles and can weld could put one in our year of truck, or if it would even fit.
Justin
Justin
69 lwb project: http://67-72chevytrucks.com/vboard/s...d.php?t=558011
72chevynoob is offline   Reply With Quote
Old 12-12-2012, 03:24 AM   #2
502ms
502ms's Avatar
Re: duramax in a '69?
I don't see why not. Just measure twice...
Definitely document the whole conversion. I had a 1970 with a Cummins 6bt in it. 1200lbs of diesel power. You can do it
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 12-12-2012, 04:02 AM   #3
SS Tim
SS Tim's Avatar
Just do a site search there are many posts on this subject.
SS Tim is offline   Reply With Quote
Old 12-12-2012, 07:49 AM   #4
hugger6933
Those motors are still bringing that kind of money. What trans does it have? If if were the allison they too bring good money still. There will be other parts no matter how hard hit the truck is. I don't see how you could go wrong ,even if you had to part it out you can make some money on it. I would do some research on the wiring that will be the most difficult thing of all in the project and prbably the most expensive after you have the engine purchased.
hugger6933 is offline   Reply With Quote
Old 12-12-2012, 08:40 PM   #5
72chevynoob
It does have an allison, which I would hang onto unless some one wanted to trade an nv4500for it, and Im sure a lot of the interior is still salvageable.
Justin
Old 12-12-2012, 09:02 PM   #6
fastlane
fastlane's Avatar
I used to subscribe to diesel world, and every other month someone would make the cover by having put a oil burner in an old truck. the most popular way to go about it was to put the old body on the new frame. The most labor intensive would be to make the diesel fit.
In a 69, the body is to small to fit properly on a new frame. Or at least thats how it looks sitting next to my cummins. my 69 swb stepside is only slightly bigger than my wifes accord.
1969 Chevy C/10 Stepside, Short Box. LQ4/4L80E swap in progress! (Donations being accepted!)
fastlane is offline   Reply With Quote
Old 12-12-2012, 09:27 PM   #7
1972RedNeck
1972RedNeck's Avatar
I have read just the opposite. To me it seems it would be easier to make 3 new mounts instead of however many the body has.
I have looked into sticking a cummins in a ford a fair bit and have deduced that a motor swap is easiest.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-12-2012, 09:29 PM   #8
72chevynoob
Mine is lwb and we actually measured them at work and they are the same wodth approximately. Im not sure if my parents are gonna let me buy it. I might have to wait until i am done high school, bevause they dont seem too excited about me dragging home another vehicle.
Justin
Old 12-12-2012, 09:40 PM   #9
72chevynoob
And yeah, i was thinking more along the lines of same frame, swap engines. Does anybody know the weight difference between a sbc and a duramax?
Justin
Old 12-13-2012, 12:47 AM   #10
HotRod C/10
HotRod C/10's Avatar
might be able to find a weight on an ebay listing for DMAX engines....just a thought.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 12-13-2012, 01:23 AM   #11
Rusbuilt
Rusbuilt's Avatar
Check out this build.
http://67-72chevytrucks.com/vboard/s...d.php?t=472138
Rusbuilt is offline   Reply With Quote
Old 12-13-2012, 01:29 AM   #12
72chevynoob
I dont think its gonna work out. He said he sold the starter, so I can't here it run, bit its a perfectly good engine. And the parents definitely werent too impressed with another pos either. I did find weights, though, if anyone is interested. A duramax weighs around 850lbs, but a 350 weighs around 575, and a 454 weighs around 650. So only 200lbs more than a stock option in these trucks. Thats impressive considering a cummins weighs around 1200lbs.
Justin
Old 12-13-2012, 01:40 AM   #13
WIDESIDE72
WIDESIDE72's Avatar
I had a similar situation when I was going to buy a vortec 350 still in a wrecked truck. Seller said it ran but he had sold the starter. I told him I would buy a starter and install it. If it ran and had good compression numbers like he said I would give asking price. If not he woul pay for starter. He never called me back. Huh. Go figure.
WIDESIDE72 is offline   Reply With Quote
Old 12-13-2012, 12:40 PM   #14
skorpioskorpio
Duramax is a completely electronic engine, so you better make sure you get the whole harness, pedal, transmission and all if you are even considering such a swap. It uses a very high pressure fuel rail so that it can atomize the fuel to the point that it doesn't need a prechamber. It's a very different beast than the 6.2 and 6.5 engines that are more traditional Diesels. It's drive by wire and there is no other option in such a design and the harness is tied into just about everything. A lot of the Duramax swaps I've seen end up swapping in the dash as well. Impressive engine but not so easy to retrofit.
skorpioskorpio is offline   Reply With Quote
Old 12-13-2012, 01:11 PM   #15
clear
http://www.dieselpowermag.com/featur...0/viewall.html
clear is offline   Reply With Quote
