narrowed axle question
I have a 70 c/10 i just purchased a 9 inch,I would like to narrow it as much as possible can any on give me some insight on this i would greatly appreciate any help.
Re: narrowed axle question
You can make it a narrow as the centre section plus the flanges, but that is pretty narrow . You will have to order new axels to fit accordingly... What I did, I put the wheels im running in the wheel tubs, got them where I wanted them to sit then measured the distance. I ordered mine, so I had a few measurements that they needed..
67- 72 Parts collecter |
![]() Join Date: May 2007
Get your wheels and tires FIRST! Then make the axle fit between them.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
![]() Join Date: Oct 2012
If your plan is to have big wide tires in the rear, when widening the tubs you should also raise them, so you can get it low and around the tires.....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
get the rims and tires, get the axle, then get the stance...then the tubs..
#6 | |
more information is needed. like who/what/when/why/how.. seriously though, how wide of tires you want, how wide of wheels, how much are you narrowing your frame, what is your ride height, so on and so on. basically what are you trying to do? |
I am not going to narrow the frame it is lowered 4 in , i would like to run 335/45/zr20 i really llike the deep off set rim look
