Restoring old paint
Hey Everybody - somebody on here a couple of years ago was talking about using CLR or something like that to take a truck with original or very old paint and clean it up. From what I recall, the sun faded spots still show around the edges, but it cleaned up and brought back a lot of the original paint.
I'm considering buying a truck with a nice patina to it, but would like to clean it up and bring back as much of the original paint as possible. Thanks, Pat aka 2ndgenrr
The Stable: 1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me. 1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck. 1951 Chevy 1/2 ton, 3-window...building to sell. Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado. I grew up in Flint, Michigan so I can't help but to bleed Chevy! |
Re: Restoring old paint
Usually they do that when there is surface rust showing but plenty of old paint left. If the paint is fairly good with no rust the CLR should take off the surface scum like the what hard water leaves on it so you could rub it out and try to bring the paint back.
I have used both CLR and Soft Scrub with great results. Here's the last truck I did the CLR treatment with. I used it uncut, with a red scotchbright and it was a completely different truck. On the milder "Patina" rigs, I have used a softer grey scotchbrite or a mild plastic kitchen sponge with Soft Scrub
That's exactly the info I am looking for. Thanks for your responses!
If the paint is just faded and dead but there is no surface rust on it you can just use Comet or Ajax cleanser on a rag or 3-M pad, with water. It won't do anything with surface rust like CLR but is cheap and works good.
#6 | |
![]() Join Date: Apr 2009
For safety, wear good quality rubber gloves and eye protection when using CLR. Posted via Mobile Device |
I had pretty good luck with full strength CLR and a bunch of green scotchbrite pads.
Moderator
![]() Join Date: Dec 2012
If you just want to bring back as much as the original paint as possible, use Meguiar's Ultimate Compound.
if the body isn't rusty any buffing compound will remove oxidation
you can do it by hand with a rag or with a buffer if the body is rusty, clr will get the rust out pretty amazing results for newfisher and coach
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Agree with Ogre...results are amazing. I would say that the truck I'm looking at is somewhere in between the two in condition. I'm in Michigan so it definitely has rust, but not bad....
Scotchbrite !
Before ![]() After ...... with clearcoat ![]()
Chris '69 C-20 '04 Jeep TJ |
What did you use for clear?
#13 |
I thought that was Coach's truck!
#14 |
Come on Coach ! Dont ask me hard questions
![]() A buddy of mine did it at his shop ....... I cant tell you what clear he used. ![]()
#15 |
It turned out great....but a litle too shiny for me. Looking for a more satin finish if I was to do mine!!
#16 |
![]() ![]() Join Date: Nov 2008
Maybe it only looks THAT shiny because its inside a paint shop, directly under overhead lighting they might use when cutting and final polishing cars post-painting?
I think it looks great though I'd throw a new set of original hubcaps on it. Posted via Mobile Device |
#17 | |
or it will be real rusty, as in no usable parts ![]()
#18 | |
#19 |
Send it to Oregon, I'll drive it around and knock the shine down for ya
#20 | |
I just want a ride in your 'burb !
#21 | |
Thanks again to all who replied with your results...very helpful.
