Old 12-12-2012, 02:13 PM   #1
jimboh247
jimboh247's Avatar
Which bolt goes where??
Pulled the 305 out of my 85 to regasket it, put in a cam etc.
I neatly bagged up all my bolts, labeled them etc. Just like I should.
But.....
I can not for the life of me remember which bolts go where on the exhaust manifolds. There are 3 different lengths and some of them are threaded for a nut, obviously for the AC or power steering or Alternator.
I still have all the heat sheilding etc.
Does anyone have a manual they can look up, or point me to one on-line?
'85 SWB Silverado
jimboh247 is offline   Reply With Quote
Old 12-12-2012, 02:16 PM   #2
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: Which bolt goes where??
But.....
If it has the log A/C (don't know based on year) the studed one should be the first bolt on the drivers side, and there would be a longer bolt in the second hole on the drivers side that goes on a bracket that the first hole goes on. The rest should be the same. (it was in my case).
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 12-13-2012, 10:50 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
with no AC i have the stud one drivers front for the power steering pump
can't remember if the heat riser bracket ones were longer
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-14-2012, 05:54 PM   #4
crazeetxn
crazeetxn's Avatar
I would give you some pics, but, uh, I have mine on a stand too
When I pulled it a few years ago, I could't remember either. Folks provided good info, but I ended up going to a junk yard and rumaging around til I found an engine setup like mine and took pics of the thing. Got back home and did the slap on the forehead thing...
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
