berghandler
I'm considering starting my second restoration of a 70's vintage Chevy truck. The first one was a simple C10, 6cy, three on the tree. Now I'd like to try bigger, a C20/K20 4x4. I've got a chance to pick up a complete good running parts GMC truck with no title but want to make a Chevy when I'm done. I know the fenders and grill are not interchangable from GMC to Chevy, but what about the hood, doors, cab and box from the GMC? Can I use them along with Chevy sheetmetal parts? And rad support and inner fenders fomr GMC truck? This is a 1970 GMC and I'd like to end up with the 72 Chevy look with the lights in the front bumper etc. Do 69-70 Chevy doors and hood fit 71-72 chevy body?
Lots of questions I know but I don't really want to buy the parts I'm looking at if I can't use them. Thanks |
Junior Member
Re: berghandler
Here is one answer. Doors from 67-72 GMC/Chevy are interchangeable. I have 1970 doors on my 1967. The '72 doors are slightly different, but they fit fine, they have a screw below the vent window on the door and the window regulator has a longer shaft because the door panel is thicker.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: berghandler
The core support is different (4 lights) but I think you could modify it if you had to. Cab, doors and bed are the same.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Re: berghandler
I believe the hood should be fine, although you will have to fill the holes from the GMC letters. Doors, cab, and box will be good as well (save for the tailgate, which may say GMC).
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
