66 Frame w/ 1987 Disc brake Cross Member question
Just putting the final touches on swapping in a 1987 Disc Brake front end under my 1966. I was surprized with how simple it was to do.
I got the motor mount frame brackets from the 1987 and I discovered the brackets are too tall for the 1966 frame. Apparently the 1987 frame is 3/4" taller. For you guys who did this conversion, did you use the new brackets with 3/4" spacers or did you reuse the original 1966 brackets? If I had spacers made, would that affect the installation height of the engine? Thank you, Kevin C
1988 C1500 Regular Cab, Long Bed, 2WD. |
#2 | |
Re: 66 Frame w/ 1987 Disc brake Cross Member question
http://kieth.smugmug.com/Trucks/66-G...9244&k=NP2nXZh after you go to the above photo just click thru the thumbnails and you can see how we did it. Kieth 66 ![]() Last edited by kieth; 12-13-2012 at 03:27 PM. |
I did the opposite added 1/2 spacer on top of frame, it's been 20 years, seems fine.
1961 crewcab
if you can source a 2wd 3/4 ton set they are a direct boltin, since the 3/4 frame is not as tall as the 1/2
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
This
Or you can shorten the C10 motor mount brackets.....or just add the spacer to the top of the frame. Either way you will want the bottom of the bracket on the crossmember. You will also have to trim back the top flange of the frame, for the later model motor mount brackets. If you still have the '87 frame you can use that as a reference.
Why not just use the original mounts? Worked for me...
I wanted to use the later model motor mounts because of the large size of the bracket and the rubber isolation material. I also wanted to keep the engine as low as possible and just a little forward so it did not touch the firewall. Kieth
60-66 Nut
The original style motor mounts can pull apart and let the engine move around. The '73 and up 'clamshell' motor mounts will not pull apart and let the engine move around.
Looks like either way I go with this, I need to notch the top part of the frame. Redrilling the crossmember so the top of the bracket sits flush to the top of the frame effectively moves the motor mounts closer together. Didn't that cause any issues when the motor went in?
