Old 12-13-2012, 05:13 PM   #1
BENC-10
Exclamation Anyone install an "ez efi" kit?
Hey, everyone. Came across a killer deal for the ez efi master kit. But before i pull the trigger, just want to know what some of the problems i could face (if any!) I am running it on my stock gas tank, which i dont know if it will work or not..If anyone has it installed i would like to know the steps you guys did. Thanks
BENC-10 is offline   Reply With Quote
Old 12-13-2012, 06:01 PM   #2
derrickmanx1
derrickmanx1's Avatar
Re: Anyone install an "ez efi" kit?
I have one. It's great just be careful where you route the wiring. Also follow the directions. If you don't have them go to the fast website and print them out. Take your time and enjoy.
NAME: TRAVIS TRUCK: BRUISER
71 C/10 SWB 3.5/5" drop 4.11 GEARS.
F.A.S.T. BBC 408 496hp/479ft/lb
JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL
My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530
derrickmanx1 is offline   Reply With Quote
Old 12-13-2012, 08:10 PM   #3
BENC-10
sweet!!! thanks! are you running the system with your stock tank?..my buddy was telling me that since its f.i it has to have a return line going back to the tank? Thats about the only concern i have, at this point the system itself looks pretty straight foward haha
Old 12-13-2012, 09:05 PM   #4
70c10stepside
Carb>efi :p Save the carbs! Electronics are killing everything..
70c10stepside is offline   Reply With Quote
Old 12-13-2012, 09:50 PM   #5
eagleuh1
eagleuh1's Avatar
Everything but my pocketbook, in the long run anyways.
eagleuh1 is offline   Reply With Quote
Old 12-13-2012, 10:26 PM   #6
Ackattack
Ackattack's Avatar
I put a tbi engine in my 69 truck and switched to a 72 sending unit. It has a vapor recovery thing that can be used for a return line. I also put a TPI engine in my 72 truck and did the same thing. Both of them used a frame mounted fuel pump. The only issue with using the stock tank was on the TPI truck it would cut out a little when you ran low on gas going around a corner. So I just kept more than a 1/4 tank.
Ackattack is offline   Reply With Quote
Old 12-14-2012, 03:46 PM   #7
BENC-10
Cool, I had researched a little and found that 72 sending unit too, but i wasnt sure if it was going to work! lol.. THANKS FOR THE ADVICE! ill try and post pics when i install it
