Old 12-13-2012, 07:13 PM   #1
Yesca 71
2WD Front End Lift Question
I Have my 71 GMC 3/4 ton front end tore apart and its getting all new goodies. I want to raise the front end approx. 2'' does oreiley or someone like them have some sort of rubber spacer i can put on top of or bottom of the coil????
Yesca 71 is offline   Reply With Quote
Old 12-13-2012, 07:24 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: 2WD Front End Lift Question
I replaced the front springs in mine with Moog stock big block with AC springs. It gave it a good lift. They were about $100 or so when I bought them. In the pic I have stock size tires on it and have had up to 33's on it with little or no rubbing. I tried the Rancho lift springs but they were too harsh. BTW the engine and tranny in the truck weigh considerably more than the stock setup.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 12-13-2012, 11:00 PM   #3
72 K20
72 K20's Avatar
What setup are you running ?
72 K20 is offline   Reply With Quote
Old 12-14-2012, 09:27 AM   #4
Longhorn 70
I don't know what you mean by that but enging is Olds 425 and 700r4 behind it. It is a Longhorn with stock suspension except for the Moog replacement springs for BB and A/C.
Old 12-14-2012, 11:09 AM   #5
Yesca 71
Im running all stock. Have new coil springs, tie rods inner and outer ball joints etc. I was just looking for an inexpensive way to do this
Old 12-14-2012, 11:23 AM   #6
longbed67
longbed67's Avatar
If you lift another 2" wont you bottom out your upper control arm?? Which would make for a terrible ride and handling going down the road as you wont have any room for your tire to drop when it goes over a bump or down into a dip....
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 12-14-2012, 07:55 PM   #7
72 K20
72 K20's Avatar
Vince
I was curious as to what setup you had that the BB springs would give the lift that you wanted.
How much more does the 425 weigh than a SBC ?
Old 12-14-2012, 08:04 PM   #8
Longhorn 70
The BB Olds and 700r4 together are about 180 lbs more. The TH350 and 350 that were in there The tranny is 30 or so and the Olds is 150 more or so.
I have tried to find the number of the springs I installed but no luck. I'll keep looking.
