Old 12-13-2012, 07:47 PM   #1
Longhorn 70
Longhorn 70's Avatar
Disc conversion issues
I have received a disc brake conversion kit for my Longhorn. Upon inspection I see the lugs on the discs are much larger diameter. Are 72's 9/16"? I have a line kit, dist valve kit and new master cylinder/booster on the way too.
I can hardly wait for more issues to arise. Anything I should look out for?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 12-13-2012, 10:32 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Disc conversion issues
Yes, 71s and 72s were 9/16". Earlier w/drums were 1/2".
FirstOwner69 is offline   Reply With Quote
Old 12-13-2012, 10:35 PM   #3
davepl
davepl's Avatar
Yep. I did this on my '70 and wound up replacing all the studs up front with the 9/16" that they came with (off a 72) and converting my rear Dana60 to 9/16 also, which started life as 1/2" studs.
I suppose you could run mismatched studs (9/16 up front and 1/2 in the rear), but I wanted to get them all the same size.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-13-2012, 10:46 PM   #4
rico7769
Hybrid67
rico7769's Avatar
good info. Prob going to order the same set for my 67 sometime next year
Keep em' Running!
All show.....no go
rico7769 is offline   Reply With Quote
Old 12-14-2012, 09:29 AM   #5
Longhorn 70
Thanks davepl. Was the rear stud change difficult? Or was it pound the 1/2"s out and press in 9/16"s in the drums? Heck maybe I'll do a rear disc too. They are about $500 from BlackBird.
