Old 12-13-2012, 08:12 PM   #1
1979cstepside
1979cstepside's Avatar
Bagging a 1979 chevy stepside?
Hi I was wondering how much money it would take to bag a 1979 stepside chevy if anyone could let me know that would be great!
1979cstepside is offline   Reply With Quote
Old 12-15-2012, 07:00 AM   #2
bk2life
Re: Bagging a 1979 chevy stepside?
1500-7500.
bk2life is offline   Reply With Quote
Old 12-15-2012, 07:45 AM   #3
andrewmp6
Depends a lot on what you want like just lower it good or fully lay frame.Wheel size can matter so can your budget too.If you just want it lowered good take a look at ridetech.com
They ain't the cheapest but the best at bolt in and lowering good.If you want it to lay frame porterbuiltfabrication.com or scottshotrods.com .
andrewmp6 is offline   Reply With Quote
Old 12-17-2012, 06:34 PM   #4
1979cstepside
Originally Posted by bk2life View Post
1500-7500.
Ok we'll what do you think the cheapest set up would be money wise?
Old 12-17-2012, 07:02 PM   #5
Pro Performance
Pro Performance's Avatar
As mentioned above, there are many ways to bag the truck, and all depending on what your goal is. We offer a few different levels of air ride kits, with the entry level being the Pro1. These kits use the Porterbuilt suspension, as well as quality components from AccuAir and VIAIR. To do the rear correctly, it is best to change to a 4-link or trailing arm setup vs. the leafs.
Pro 73-87 Air Ride Kits
http://www.azproperformance.com/Pro-...Kits73-87-C10/
Pro1 73-87 Air Ride Kit
http://www.azproperformance.com/Pro1...-Ride-Kit.html
The Pro1 can be done with a 1/4" air management system, which would cost $625 less, making it $2,504 for the complete setup without spindles.
Let me know if we can help you out any. If you are looking for a basic system to air bag the truck, and not wanting to lay frame, the Pro1 is an ideal kit. Everything stays under the bed and is all bolt-on, with the exception of the axle brackets for the trailing arms.
Travis
Pro Performance is offline   Reply With Quote
Old 12-17-2012, 11:51 PM   #6
1979cstepside
K
Travis
ok we'll I would like to keep it under 3000$ and I want it to be as close to slamming it to the ground so what's a whole kit gonna cost me?
Old 12-18-2012, 02:13 PM   #7
Pro Performance
PM Sent. It can be under $3,000
