12-13-2012, 10:09 PM | #1 |
Differential breather
Hey guys,
my stock diff breather was broken off. I was able to thread a 3/8 bolt into the hole. Is this the typical thread? i have found differntial breather for sale from summit and other sites but none are this thread. Any ideas? Thanks Kris |
12-14-2012, 01:39 PM | #2 |
Re: Differential breather
bump
12-14-2012, 01:41 PM | #3 |
My educated guess is that it is pipe thread. I would look at 1/8 pipe, that is approx 3/8 dia
Posted via Mobile Device |
12-14-2012, 02:00 PM | #4 |
last i saw it was NOT threaded...it was a press in fitting...but you can tap one in..
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
12-15-2012, 12:19 AM | #5 |
60-66 Nut
Depending on which differential you have it will be either a pressed fit or 1/8" pipe thread.
