Dome light switch
I was wondering if when you turn the headlight switch to turn on the dome light if the switch completes the ground or supplies power to the dome?
I moved my dome light to door jam switches but got to thinking if it's the ground on the switch I could wire that in to then also have the interior lights on the doors and the switch. I can test it... but maybe someone knows off the top of their head. Thanks, Scott
------ 65 Chevy C10 Fleetside |
![]() Join Date: Sep 2011
Re: Dome light switch
I'll be doing this mod shortly:
http://www.persh.org/Pickup/DomeLight.htm Bottom of the page states that it completes the ground.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
![]() Join Date: May 2012
Just did door switches on mine ,no power just ground, white wire coming from dome to headline switch. Really ez.
John Posted via Mobile Device |
Senior Enthusiast
For further clarification (if it's needed) the dome light has constant power. The ground at the headlight or door switch(es) completes the circuit illuminating the light.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 12-15-2012 at 08:46 PM. |
Thanks for the info guys! Simple enough to wire in to my door jam switch setup then.
