Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-13-2012, 11:45 PM   #1
richards72chevy
richards72chevy's Avatar
Best thing to fill the cracks on my floor.
I have bad cracks along the opening of my garage door.Its a pain trying to get an engine on the picker over the cracks.I have seen people use concrete but that cracks real easy.Do you guys have any suggestions?
richards72chevy is offline   Reply With Quote
Old 12-14-2012, 12:04 AM   #2
cableguy0
Re: Best thing to fill the cracks on my floor.
How wide are the cracks? How thick is the floor? Do you know why it cracked? Is the ground soft or shifting under the concrete? If the ground isnt stable it wont matter what you use to fill the cracks its going to break up as the ground moves or settles.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-14-2012, 12:16 AM   #3
richards72chevy
The cracks range from one inch to about four inches.Im not for shure how thick the floor is.Im thinking the concrete poured over the old concrete was not mixed rite or maybe the drougt is causing this.
Old 12-14-2012, 10:14 AM   #4
thesledhead
thesledhead's Avatar
Is the slab level on both sides of the crack? Typically when a slab cracks due to the ground shifting or settling it leaves one side of the crack higher than the other. If its level there are a ton of great products you can use but if the ground is shifting you're screwed.
thesledhead is offline   Reply With Quote
Old 12-14-2012, 10:41 AM   #5
ETsC10
Hand Crafted C-10
ETsC10's Avatar
I've used Quikcrete vinyl patcher but it's usually only recommended for shallow cracks. Works very well.
I've heard that for deep and wide cracks you can mix builders sand with a concrete fortifier.
ETsC10 is offline   Reply With Quote
Old 12-14-2012, 12:28 PM   #6
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
http://semproducts.com/product-catal...ible-sem-weld/
This stuff is used to repair plastic bumpers.
I have used SEM weld to repair holes / cracks in the shop floors here at work. The millwrights have used concrete vinyl repair in the same areas, SEM weld lays flatter while still remaining flexible (important in floors). SEM weld can also be sanded flat, which I did for our loaded pallet jacks constantly running over it .
You can probably locate some at the local auto body & paint store
johnnyclack is offline   Reply With Quote
Old 01-05-2013, 12:13 PM   #7
77c10
77c10's Avatar
Sika 1A polyurethane sealant works well for sealing the cracks up and it remains flexible. Not sure that it would really help with rolling anything over it though.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 01-05-2013, 12:32 PM   #8
67swb72klb
67swb72klb's Avatar
go to a flooring supply store there is a bunch of different floor prep products to pick from
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
