Old 12-14-2012, 12:08 AM   #1
Dano69c10
Dano69c10's Avatar
Re-inforcing TA x-member?
I want to run my exhaust through the ta x-member. Do I really have to reinforce the holes with pipe?
I was looking at this and it looks like I don't have to do this.
http://www.classicperform.com/Store/...ck/6372LDL.htm
Thanx in advance
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 12-14-2012, 12:12 AM   #2
andrewmp6
Re: Re-inforcing TA x-member?
How big of exhaust are you going to run?If you plan on lowering the truck i would run this one http://www.porterbuiltfabrication.co...olet-Truck-249
andrewmp6 is offline   Reply With Quote
Old 12-14-2012, 12:46 AM   #3
Dano69c10
Dano69c10's Avatar
I'm going to run a 2 1/4" exhaust pipe.
Nate's crossmember is nice, but unfortunately not in my budget for my truck.
I'm also trying to do my own modifications, rather than going the buying/bolt-on route.
The only rivets I want to remove are the TA mounts and then flip the mounts.
Dano
'69 Fleet
Old 12-14-2012, 09:27 AM   #4
SCOTI
SCOTI's Avatar
The aftermarket x-members are thicker @ .250" vs the stock stuff. I'd reinforce things & no 90* edges when cutting to prevent future stress cracks. Not necessary to utilize pipe but some plate or similar would still help.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 12-14-2012, 10:44 AM   #5
Dano69c10
Dano69c10's Avatar
Thanx!
'69 Fleet
Old 12-15-2012, 10:44 AM   #6
midniteblues
midniteblues's Avatar
I just put this on the custom mods thread.
I'm doing the same thing and figured if I cut the pipe long enough I can tie them into the front of the c member just for lil'added support and a place too put some hangers later on still havent decided on 2 1/2 or 3" exshaust yet but my tubes are 4 1/4" so I'll have plenty of room either way
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 12-15-2012, 03:23 PM   #7
Daaaanz67
Here's mine 3" I'd pipe with 2 1/2 exhaust. Thers a hanger right where it goes through the x member to keep it from hitting
Daaaanz67 is offline   Reply With Quote
