12-14-2012, 02:05 AM | #1 |
1970 Daily Driver
Need help to ID front suspension clip
Can anyone tell what this frontend might be? Would there be a vin number located some where that would help identify it?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
12-14-2012, 02:35 AM | #2 |
Re: Need help to ID front suspension clip
all i see is an alternator and a steering gearbox..
but if you get pics of the actuall frame rails/control arms ccan be more of a help. from that 1/4 picture of the UCA looks like s10. |
12-14-2012, 11:46 AM | #3 |
1970 Daily Driver
More Pics, they got fliped upside down some how
12-14-2012, 12:28 PM | #4 |
1970 Daily Driver
12-14-2012, 05:30 PM | #5 |
I'm guessing maybe a camaro subframe. look in this thread and compare. Here is a pic from that thread. look at the upper control arms, see the hole where you can reach the upper shock and the way the inside of the control arm curves??
http://67-72chevytrucks.com/vboard/s...d.php?t=220256
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
12-14-2012, 09:04 PM | #6 |
1970 Daily Driver
It sure looks like that may be the match. Are there any vin numbers on these camaro frontends that may help me pin down the year or range of years. That way if i need part i can give the parts house the correct application to look up.
12-16-2012, 01:13 AM | #7 |
Looking at the nuts on the A frame shafts I am thinking that it is a later front end than what the rear axle came out of. I think they used a nut and lock washer up through 72 and switched to the lock nut like that in 73. For a while in 73/74 some less than smart GM purchasing agent bought A frames with nuts that didn't lock and didn't have lock washers and the nuts backed off the shafts. I made a lot of money in that period taking those nuts off Pontiacs and putting the correct lock nuts on. The 71 Chevelle spindles were a two piece thing too with separate caliper brackets or backing plates for drum brakes along with steering arms that bolted on.
12-16-2012, 02:06 PM | #8 |
1970 Daily Driver
If I went to get parts could I just use a 73-81 Camaro application?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 12-16-2012 at 02:16 PM. |
12-26-2012, 08:39 PM | #9 |
Scrapper 1
a clear give away if the front steer steering box that is from a Nova even up to 193 camaro's still used a rear steer box behind the front end near the fire wall i think i have a pic of the 1972 front frame
12-26-2012, 09:02 PM | #10 |
def a 70-81 camaro.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
