Old 06-06-2003, 09:50 AM   #1
wanted
Question front axel swap
I recently bought a 70 gmc 3/4ton 4x4. This is my first experience with this this era of trucks.
It has a stock front axel with drum brakes and no power boost. I want to add disk brakes and power. I am assuming I can swap in another front axel with disks on it. I found a yard near here that has a 3/4 ton gm axel with 4.11 gears and disks but I don't know the year. My question what years will directly swap into my truck with no modification? Also, I know I need a proportioning valve for disks but would I also need larger diameter brake lines?
Any info on this swap would be appreciated.
thanks
wanted is offline   Reply With Quote
Old 06-06-2003, 11:52 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
First off, don't throw that axle away I might need parts of it. Second the 3/4 ton front end is either another dana44 or a 10 bolt GM either will bolt right in. You'll need to get the appropriate brake hoses (the banjo fitting is different between the dana and GM). Third need a new master cylinder w/ booster and proportioning valve. What appears to be a proportining valve is not. I'm in the process of fixing my front drum brakes w/ parts from Jerry Moss. I'm being a little nostalgic about not upgrading but if the parts he sends me don't fix it I'll probably upgrade myself. You'll get more good input on this.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-06-2003, 01:09 PM   #3
jerry moss
Born Psycho
jerry moss's Avatar
i'd stay with a dana 44 front diff, which i believe was used through 78. the later 10 bolt corperate front diff's will work but use smaller axleshafts. i'm using a 78 front diff under one of my trucks but be sure to check axle tube diameter. there are two diffeent tube diameters, 2 3/4 inch and 3 inch. your 70 is 2 3/4 and if you get one with 3 inch tubes, you'll need the u-bolts and u-bolt plates to match it.
when i put a disc front under my 69 i used a 75 diff and used adapters to match the brake line fittings at the frame connections.for the master cylinder/prop valve assembly, i used a complete unit from a 72 and again i used adapters for the brake lines. it's actually an easy swap once you get the adapters for the brake lines.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
