Old 12-14-2012, 10:03 AM   #1
71monteme
71monteme's Avatar
lower ball joint
my 94 gmc needs ball joints replaced, the lowers are pressed in. i see a lot of bolt on lower ball joints, can i convert my pressed in to the bolt on?
thanks for the help.
thanh
71monteme is offline   Reply With Quote
Old 12-14-2012, 10:23 AM   #2
Zane M
Re: lower ball joint
I don't know the answer, but I question "why?"
You are going to have to press the old ones out anyway, so pressing the new ones in shouldn't be a big deal at that point.
Zane M is offline   Reply With Quote
Old 12-14-2012, 06:00 PM   #3
71monteme
71monteme's Avatar
i figures it will be easier if and when i have to redo them. no special tools.
thanh
Old 12-14-2012, 07:43 PM   #4
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
Not sure on 2wd, on all 3 of my 4X4s the OEM ball joints are riveted to the LCR, you drill then punch out the rivets and then the replacements bolt in, using the holes from the rivets.
I'm not sure if the LCA's are the same or not, but something tells me they aren't.
93 Yukon
89 Silverado Z71 SWB Sport
91 K 2500 Silverado "Lobuk-Worktruk"
A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO.
Gettin' old ain't for sissies.
TennesseeZ is offline   Reply With Quote
Old 12-14-2012, 08:59 PM   #5
clinebarger
Buy some Moog ball joints & press them in, Grease them often & they will last the rest of the trucks life, No need to reinvent the wheel.
4X4 LCA's wont work, No spring pocket.
clinebarger is offline   Reply With Quote
Old 12-15-2012, 04:46 PM   #6
71monteme
71monteme's Avatar
thanks guys.
thanh
