Old 12-14-2012, 11:30 AM   #1
montefreak
montefreak's Avatar
correct v-8 crossmember
Found a v-8 crossmember on ebay out of a 70 3/4 ton 2 wheel drive with a th 350.....question is ...is it the same crossmember that i need for a 67 1/2 ton with a th 400.????? Need help quick ..auction goes off in 15 hours.....Thank you all so much.....
montefreak is offline   Reply With Quote
Old 12-14-2012, 11:40 AM   #2
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Re: correct v-8 crossmember
It looks correct to me! I have several but I cant inspect it from this angle. The crossmember bolts in different holes (on the frame) depending on the which motor and transmission you will be running.
Dont forget if you are looking at another thread they may not run the same combo you are. The mounting holes on the rear of the transmission should be in the same position on either trany. If Im off someone please step in...
Mike
Cash3481 is offline   Reply With Quote
Old 12-14-2012, 11:54 AM   #3
BarryB
BarryB's Avatar
yeah it looks correct to me, fortunately on these trucks, where the crossmember goes the frame is flat so it can be put anywhere you need it to be. you just need to drill new holes. But like ^ ^said The transmissions are pretty much the same length so it should in place no problem.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-14-2012, 11:58 AM   #4
nlped
nlped's Avatar
You know you can build your own out of round or square tube and save yourself some money and scrubbing?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 12-15-2012, 11:52 AM   #5
montefreak
montefreak's Avatar
Thanks for all the help.....i got the crossmember for 50 bucks......
