what kind of sealant to stop water leaks?
I've got the water the glovebox, water down the kickpanels, water on the floorboards and even water dripping from the sunroof blues! I tried some clear silicone from Home Depot on the sunroof and it didn't work that well. The paint shop had a tube of 3m automotive stuff, but it was $22.00 per tube! What are you guys using to stop leaks in the roof drip rail and under the cowl? I've also got to seal the glass and the brackets for the sunroof.
1967 GMC 1500 SWB. Driving this truck since I was 14. |
Re: what kind of sealant to stop water leaks?
There is a reason why 3m stuff is expensive... it usually works, but I would call 3m and see which of their product works best for your specific situation, then look online for the best price...
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
Active Member
![]() Join Date: Jul 2007
Agree with above re. 3M but if your low on funds like a lot of us these days, use some marine type sealant and lay a fine bead along the drip rail. Mine was already sealed and painted and I used the sealer as a precaution. Something to be aware of is that a lot of guys don't like to use any silicone based stuff as a primary sealer caues it keeps the paint from adhering properly.
Another thing to check.. Mine used to get a small puddle on the floor board and the glove box would get all soggy inside. After sealing everything I could think of I found the wiper motor seal was the culprit. I used engine black sealant on the wiper motor seal. No more puddling inside.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Check the antenna cable where it comes into the cab, smear the heck out of it with black RTV silicone, dried my glovebox right up!
Active Member
![]() Join Date: Nov 2012
I just sealed my radio antenna gasket last week and my glove box is bone dry now. Still get the puddle on the passenger side floor mat tho. I used the 3M stuff for the antenna because as stated earlier it works good.
67 C20 283/4 Speed |
1969 Custom 30 wrecker
The black seam sealer from Eastwoods is really good. I think it's 14.99 a tube.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Active Member
Did the same on mine especially during hard driving rains and after sealing everything I could think of including cab seam inside cowl (second pic) resolved by replacing large rubber seal on wiper motor as I mentioned above. Check it out carefully. Water travels along the bottom of dash panel inside and exits on the small openings under it ( first pic).
Active Member
Good pics. I'll check that out.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Stay 100 miles away from your truck with silicone!! All you are going to do with that is cause huge rust problems. Silicone atracts moisture and repels paint. It also gets into the metal and will cause any new paint to fish eye! Use automotive products on your truck, not bathroom products. There is a reason why it is automotive. RTV is for engines, transmissions and rear ends, not body metal. 3M product may be expencive, but it wont destroy your truck. WES
PS.... Sorry, didn't mean to sound like a Dad scolding his son.. ![]()
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Thanks for the input, especially Wes' input re: the evils of silicone on body work. I never knew that!
I'll spring the extra cash for the 3m auto sealer product. I'll be sure to seal the little drain spot on the dash to firewall seam inside, the under cowl seam outside, and check the antenna cable and wiper motor.
You'll do well my son...
![]() Join Date: Oct 2011
Threre's some good stuff on here. I like to read your post's. I alway's learn something.
#13 |
I am still learning myself...
