Old 12-14-2012, 04:44 PM   #1
mygmctruck
Power Steering question
Currently my 1/2 ton 4x4 does not have power steering , should I looking into a whole new modern set up or would the system from that time be adequate?
I am about saving some money but not to the point were it won't be the best way to go.
mygmctruck is offline   Reply With Quote
Old 12-14-2012, 08:53 PM   #2
rsavage
rsavage's Avatar
Re: Power Steering question
You will have the fewest problems with installation by using an original set up. Guys on the parts board sell pump brackets and correct pulleys and you can always buy a rebuilt box and pump along with new hoses at NAPA or similar auto parts houses. Note: a 4X4 box is different from a 2wd box.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 12-15-2012, 07:33 PM   #3
67ctener
67ctener's Avatar
Run a stock box
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 12-15-2012, 08:04 PM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
What year is your truck? 67 and 68 don't have a dimple in the frame as used a different style of manual steering box originally. If you have a 69 and up you can use a stock box for that truck. They switched to metric o-ring fittings sometime in the 70s, so if your power steering pump is from a newer truck just get the box from the same year truck.
I previously ran an 85 box and pump on my 68 prior to converting to crossover steering and it worked great. (Not a bolt on for 68 & earlier)
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 12-15-2012, 11:14 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
Gm didn't change tommetric fittings u til the mid 80's. Back in the day I swapped a 76 box onto my 72 with no issues whatsoever.
WIDESIDE72 is offline   Reply With Quote
Old 12-16-2012, 01:49 PM   #6
bugmasta
bugmasta's Avatar
I have a 68 c20 that I run a 72 c10 powersteering box and pump on. Works great. No mods required, direct bolt up.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 12-17-2012, 01:44 AM   #7
lowrollin70gmc
Too many projects
It's the 67/68 4WD that require a conversion, 2WD has a different frame and steering box. I used captainfab's bracket (intended for 63-66) when I corrected the previous owner's shims and drilled holes. My 68 K20 kept shearing two of the mounting bolts which made for interesting maneuvers.
Andrew
