Thinking about making a project outta my C10. Would like to lower it and get some 20s but I have some questions about the drop and backpacking. Currently thinking:
2.5" drop spindles 1" front drop coils 5" rear drop coils New shocks to match Adjustable track bar (all Mcgaughy's suspension components) 20x8 Torque Thrusts 4.75" BS 20x9.5 Torque Thrusts 4.5" BS 245/40R20 front 275/40R20 rear Wondering if this combination will fit right without rubbing or anything. Any opinions, suggestions, or pictures are definitely welcome. Thanks much. Posted via Mobile Device
1977 K10 Silverado "The Heavy Chevy" - 350/350/203...Version 2.0 in progress: http://67-72chevytrucks.com/vboard/s...d.php?t=576865 1972 C10 Cheyenne "The Brown Bomber" - 307/SM465/12 bolt posi...Plans for 2.5/4" drop 1992 F-150 "The Dooley" - 351C/M715 axles/six 44" Swampers...BOSS 351 stroker pending |
Re: '72 Cheyenne - Questions About Lowering and Rims
i dont think they make Tourque Thrusts bigger than 18's.
Project 7dos
If you mean TT2, yes they do make them in 20s.
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
Yep, you're right. Oops
Yes TT2s. Wanna know if this stuff will all fit before I order anything.
Or what else will fit. Only real worry here is BS on the wheels. I like the look of as little BS as possible
The front sounds good to me. For the rear, I'd get at least a 5-5.5 BS. A 4.5 would probably be close to rubbing the bed sides when you hit a bump and gives you room to go lower if you decide to. IMO, It's better to have too much BS than not enough, bc you can always use a spacer if you don't like the look. If not enough BS, you're SOL.
Groovy. If 5 or 5.5 would fit better I would go with that then. IDK I just never liked the idea of wheel spacers, just doesn't seem like the right way to do it. Thanks LEX
67-72 parts collector,…
![]() Join Date: Nov 2002
My opinion here for a static dropped truck.
20x8 (5" BS) with a 245/40-20 tire. 20x9.5 (5" BS) with a 295/40-20 tire. I have these on my blazer (with a little more backspacing than listed above),... because it's bagged.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I would also go to a super track bar not just an adjustible. That way you can correct the angle too. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#11 | |
I would look at ECE for all the parts.
Or ChassicHeartbeat.com
#13 |
Definitely check Classicheartbeat.com. Wes has good parts and is a vital member of our board.
Danny 71 SWB |
#14 |
2WD Jimmy
![]() Join Date: Mar 2005
#15 | |||
So would it be safe to say that this combination will fit well with the exception of needing more BS in the back and an adjustable track bar?
#16 |
Good place to get Torq Thrust II wheels.
http://www.newstalgiawheel.com/wheel...ubcat3=1011103 20x8 3.625" - 5.625" bs available. 20x9 1/2 3.625" - 7.125" bs available.
#17 | |
Get your truck at your desired ride height,... THEN measure for wheels.
#18 | |
Posted via Mobile Device Posted via Mobile Device
