12-14-2012, 08:04 PM | #1 |
Hard Gas Pedal in 74
Changed from straight six and 3 speed on the column to 350 with 700R4 transmission. The gas pedal is very hard to push. We have used different springs on carb, new cables (both gas and transmission kick down). We thought it might be in the transmission as it had a full shift kit. We were going to check the springs in the transmission (found out the transmission was a mess). Ended up rebuilding the transmission. Still have the problem. Also had an angle on the cables going to the carb. Raised the mount so they are now straight. Does not feel hard at the carb. At a loss for ideas. Any help would be appreciated.
Kerry 1982 Chevy Corvette 1974 Chevy Stepside 1957 Chevy BelAir 2 Door Hardtop 1993 Cadillac Allante 1971 Dodge Charger R/T |
12-14-2012, 08:22 PM | #2 |
Re: Hard Gas Pedal in 74
Maybe the cable itself is kinked or rusty
Never mind I read over the fact that you had already replaced them.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
12-15-2012, 01:00 AM | #3 |
Robert Olson Transport
try making sure that the cable isn't kinked then shoot it through the end of the housing with WD40 or a lube
12-15-2012, 03:49 AM | #4 |
new cables, but you might have kinked them with motor swaps?
12-15-2012, 09:33 PM | #5 |
Thanks for the responses. We have put a couple of new cables on it since all the changes. It did not help.
12-15-2012, 11:28 PM | #6 |
What's the carb condition?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-16-2012, 02:56 AM | #7 |
Can you post pictures, Something might jump out. I worked on a V8 to I6 swap a number of years ago and I don't remember having to change the cables.
I can still count my vehicles on two... wait three hands. |
12-16-2012, 10:52 AM | #8 |
I swapped out my Qjet for a 2bbl Holley and I'm having the same problem. Gas medal was nice and smooth before swap and now it's like stepping on a brick. Doesn't look kinked or anything but the bracket is mounted like 1/2" higher due to the adapter.
1977 K10 Silverado "The Heavy Chevy" - 350/350/203...Version 2.0 in progress: http://67-72chevytrucks.com/vboard/s...d.php?t=576865 1972 C10 Cheyenne "The Brown Bomber" - 307/SM465/12 bolt posi...Plans for 2.5/4" drop 1992 F-150 "The Dooley" - 351C/M715 axles/six 44" Swampers...BOSS 351 stroker pending |
