got pulled over by smokey for my ride height on blocks
Hi I'm new to this whole forum thing but having a difficult time on debating on the u-bolts for my 70 c10 a few weeks ago I got pulled over by a stater for ride height clearance on 3in lowering blocks and went and got some springs from Chevy metal in Vancouver Wa that are 4in dropped I went out and picked up some stock u-bolts wondering if they would work for those springs now that the 3in blocks and u-bolts have to go or do I need to go pick up some different ones to work any advice
Posted via Mobile Device |
Re: got pulled over by smokey for my ride height on blocks
Stock u-bolts should work if you are losing the blocks.
What size wheels are you running? A 3" block is a lot. If you have 15" wheels there is a good chance that a flat tire would have had you bottoming out with the u-bolts ends. That doesn't really matter anymore though.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Yeah I'm running 15's
And I also bought the truck with those blocks on it and have hated those block since
coil springs have nothing whatsoever to do with ubolts of any kind
So are you losing the blocks in favor of the springs? If not why not just buy 6in springs
70 SWB STEPSIDE 70 BLAZER 09 challenger |
Yes I'm getting rid of the blocks hmm 6in blocks I'm going look in to getting some but that also means changing the Trac arm and relocating shocks in which I'm not to familiar on how to relocate the shocks
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
You can't do a 6" block. OARNGESI was talking 6" springs. No matter if you drop it 4" or 6" in the rear, you will need to relocate the shocks and change the panhard bar. That is if you want your shocks to function properly and the truck to track right. It's not difficult to do. I did it to my 67 panel and you can see how in my 67 panel project page in my website. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Opps yeah I mean springs not blocks hmm going to have to check out your site to get ideas thanks for seeing my typo
Welcome to the Forum Mikey. Check out the Oregon Section. We're having a Get together in Janzen beach tonight there will be a few Lowered trucks there along with a couple more guys with lowered truck projects you could talk to and see there trucks first hand.
Nice I'm going have check the time for the get together and hope I get out of work for on time and thanks for the invite
![]() Join Date: Dec 2012
Move to Arizona or Texas. They won't bother you for too low or too high (if you have flaps). We'd love to have another truck out here.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#13 |
I have got to admit Texas has a nice car scene for customs rat rods and trucks
#14 |
You need minimum 3" on cars and trucks from the lowest part of the vehicle to the ground where it is smooth and level to be legal. And a minimum 1.5" on motorcycles. If you are within that limit, you might want to call him out!
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
#15 |
BlahBlahBlah
I think the ride height clearance problem was the fact when you use 3 inch blocks something is going to hit the ground if you get a flat. I have two inch blocks with shock relocaters and if I get a flat Ill be banging those mounts on the ground. Ill have to change it up back there.
#16 |
#17 |
Well now with the info and advice you guys are giving me is awesome and I definitely think the 3in blocks aren't the greatest on the truck so I'm hoping to 5in springs will work out great but now that I've done some homework on the relocation of shocks and panbar still a lititle nervous on the diy
#18 |
In terms of DIY jobs this one is going to be pretty easy. No parts to go flying off and kill you.
The last time I did rear springs I jacked it up, put two jackstands on each side holding the frame (I always like to use a pair of jackstands AND the jack to hold it up, or two sets of jackstands). Then drop the rear with the jack until it's resting on the springs, leave the jack under the rear holding it up. Each spring has one bolt holding it in. Take it off (or cut if off if necessary). Put new spring on. Cut old u-bolts off, take blocks out, put new u-bolts on. It really is a fairly simple job. I can almost guarantee you that getting the bolts off is going to be the hardest part of the job. Be prepared to cut them off. Shock relocaters and panhard bar are about the same as far ass difficulty goes. In all reality you can make the blocks a project. Finish that and if you have time that day tackle the springs. Finish that and move to the shock relocators, finish that and move to the panhard bar. As long as you complete each one, you can drive it at any time in that process.
#19 |
Sounds pretty easy now that it's been explained I'm going to have try to order parts Monday and hope I'll have everything to do it Friday
#20 |
![]() Join Date: Mar 2012
Ive never heard of that law. Might be that way in your State tho. Normally nothing can hang lower than the rim. Incase you blow a tire, your frame and control arms and u-bolts wont hit the ground. You can run a 25 series tire and be SUPER low and still legal in most States and Canada.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#21 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
#22 |
When I got pulled over the officer said, "anything below the rim that will hit the ground in case of a blow out".
Welcome to the forum ![]() The one very important thing you have to remember when you are doing your project is you gotta take pics and post 'em ![]() |
#23 |
Thanks for the welcome bomp yeah pic are good just have to remember I usually get way to ahead of myself and forget the important part pics
#24 |
Woodburn, Oregon has alot of lowriders.....................i can see the cops mess'in with you down there....
But he must have just been Bored or a real D--K to bother with that...
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#25 |
Yeah Woodburn I a town still stuck in time capsule still trying to adapt to it since I moved up here from southern California 8yrs ago
