12-15-2012, 12:51 PM | #1 |
what differences between 67-72 cabs?
I'm looking at options to replace my rusty cab. I see a few cabs for sale locally on craigslist. Is there a difference in the cabs over the years? My truck is a 67 GMC. Any difference between GMC and Chevy?
1967 GMC 1500 SWB. Driving this truck since I was 14. |
12-15-2012, 01:03 PM | #2 |
Project Junkie! Fishing Poor!!
Re: what differences between 67-72 cabs?
You can bolt any of them on and they will work. There are differences like 67 small window or big window. 72-72 cable throttle 67-72 linkage throttle. High humps and low humps. They will all bolt on, whatever you choose just may require some modifications to be made for linkage and wire harnesses. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
12-15-2012, 01:04 PM | #3 |
Chevy abd GMC cabs are the same. WES
12-15-2012, 01:05 PM | #4 |
I am running a 68 cab on my 71 due to a fire. It went on all right and bolted down correctly. The only thing I haven't done yet is to hook up the e brake. The 69-72 has a foot brake and the 67-68 has a hand pulled brake. It doesn't look like it will be hard, I just haven't done it yet.
Danny 71 SWB |
12-15-2012, 01:13 PM | #5 |
Witch ebrake are you going to use? Hand pull or foot? WES
12-15-2012, 02:11 PM | #6 |
I haven't decided yet. I don't have all of the hand pull, so probably the foot brake
Danny 71 SWB |
12-15-2012, 05:42 PM | #7 |
There is a slight difference in the left firewall----to facilitate the length of the foot e-brake. This is a deeper recess where the e brake mounts.
Causes absolutely no difference in the swapping of cabs.
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
12-15-2012, 06:00 PM | #8 |
I have always wondered about the 71 cab...the only year that has an external embossment in the metal around the rear view mirror....WHY!!!!!
12-16-2012, 07:48 AM | #9 | |
1969 Custom 30 wrecker
While we're on mirrors, isn't it funny how they changed to a black back in 72. Supposedly due to glare or something? WOW, that sure was a big problem wasn't it. Stupid regulations...
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
12-16-2012, 08:46 AM | #10 |
why stick on? screws cost more than glue. oh, pardon me, ADHESIVE. LOL. if it wasn't a styling change or a gov't saftey mandate, very little ever got (gets) changed without a savings in cost. and very little of the savings ever makes it to the buyer.
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
12-16-2012, 09:38 AM | #11 | |
mirror post whent through his forehead when he was thrown forward. A stick on mirror would have just broken away instead.
"Negative people always seem to have a problem for every solution" |
12-16-2012, 10:46 AM | #12 |
I went with a 68 cab and a kinda of 71 feel to the trim. I know that the fuse panel mounted different. There were different fuel line applications depending on your vapor line and gas sending unit. The fuel pedal will definetly be different depending on your accelerator cable or rod . But the biigest dissapointment I have is the courtesey lights, the older cab does not have the outdent in the door pillar to hold the pin switch, weird but I know this for a fact. I decided not to use the e-brake but I know the 67-68 was a hand brake under the steering wheel and a foot brake on the newer ones. Hope this helps, Kevin.
12-16-2012, 01:22 PM | #13 |
Thanks guys, I guess I forgot about all the little differences between cabs. I've got a 67 with small rear window and hand brake under the steering wheel. I'm very partial to the small rear window look, so guess I gotta keep an eye out for that model. I found a CL ad for a guy who has repaired all the rust spots on a 67-72 cab and is selling it about an hour away from me for $600 - I was all set to take a look when I saw the large rear window - bummer. I'll keep an eye out of the "perfect" replacement cab, and if it doesn't show up, I'll repair the floors on mine and install a newer sunroof that doesn't leak and call it good.
02-13-2013, 08:24 PM | #14 |
54belair, Are you saying that the foot emergency brake can be easily installed into 68 cab with the hand brake?
02-13-2013, 09:27 PM | #15 |
If you can repair the floors on yours, you could easily "swap" the small back window frame into any "new" cab you get. Just sayin'
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
