Old 12-15-2012, 02:38 PM   #1
yellow400ex05
OOPS! HELP locked my drivers side door, now wont unlock
Alright i tried the door key for my 1957 chevy in my '66 C10's door lock to see if it would work, becuase the keys are out of a 66 era chevy. and it worked! but now it WONT UNLOCK THE DAMN DOOR?!?! what do i do? is there a trick to those truck locks?
yellow400ex05 is offline   Reply With Quote
Old 12-15-2012, 04:26 PM   #2
yellow400ex05
Re: OOPS! HELP locked my drivers side door, now wont unlock
nobody???
Old 12-15-2012, 04:28 PM   #3
luvbowties
luvbowties's Avatar
Thumbs up Re: OOPS! HELP locked my drivers side door, now wont unlock
I'd think if it locked, it will unlock. Do NOT force it OR even add 'extra pressure'. But just jiggle it; and jiggle some more; ..... May help to use a tad of WD-40. Patience, jiggling, a smidgeon of simultaneous upward--then downward--movement on end of key. Remember to smile when it opens!
Should you decide to enjoy luxury of having locking outside handles on both sides--some words of caution: I ordered these from LMC, and the locks were too big to go into my original handles. Had to then order LMC's handles to accept their locks. I think that is BAD BUSINESS. But I was mid-stream by time I realized it....plus I really needed new handles too.
HTH,
sam
luvbowties is offline   Reply With Quote
Old 12-15-2012, 04:29 PM   #4
yellow400ex05
its weird I've tried the door key for my '57 and the ignition key from the truck both go in but neither will turn it, doesn't even feel like its trying to turn
Old 12-15-2012, 05:15 PM   #5
yellow400ex05
what makes that lock button not push in all the way??? i have the panel off and want to know if theres a way to turn it manually so that when you press your thumb on the button it opens it..
Old 12-15-2012, 06:08 PM   #6
luvbowties
luvbowties's Avatar
Smile Re: OOPS! HELP locked my drivers side door, now wont unlock
...switch handles between sides. Driver's will work as normal; passenger has to be "invited"--i.e., "let" in!!!.
s
Old 12-15-2012, 08:58 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
There two different ways to lock the doors on these trucks. First is to actually lock the latch. This is done by moving the inside door handle to the locked position, which actually locks the latch.
The other way to “lock” the door is by using a key in the outside door handle. This does not lock the latch (like in a passenger car), it only prevents the door handle button from pushing in. The latch itself remains unlocked. It can still be opened from the inside by simply using the inside door handle. Also if the outside door handle is removed, the latch can be opened by sticking your thumb or a screwdriver against the latch mechanism and it will pop open.
If the problem you’re having is that the door is locked and you can't get it to open at all, it could be the latch is locked and the inside remote mechanism or arm is broken or off the latch at the back end.
Removing the inner panel should let you see what is not functioning correctly.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 12-15-2012, 10:26 PM   #8
Mack B
Mack B's Avatar
Ifim reading you right you got the interior door panel off? If so you should be able to remove the two screws for the whole handle assembly. Then from there disassemble it and reposition the cylinder to the unlocked position.
Mack B is offline   Reply With Quote
Old 12-15-2012, 11:04 PM   #9
ACK
ACK's Avatar
The lock is pretty simple. There's a tall, thin pin that slides through a tall, thin hole in a plate. When they line up, the button goes in, when you turn the key, the pin turns sideways and it's impossible to get it through the hole. Below is a really basic drawing of this description.
If you take the handle off, you can use ring nose pliers to take it apart. If you do so, there's a spring and several other pieces on the inside, so disassemble carefully and note the order in which they come out. I haven't taken the lock cylinder apart, but I'm sure finding out is easy.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 12-16-2012, 12:07 AM   #10
yellow400ex05
thanks guys i got it, i took a set of needle nose pliers and grabbed that pin on the inside of the door that goes out the end of the lock cylinder and turned it counter-clockwise and it worked! the key turned with it!
