12-15-2012, 05:19 PM | #1 |
Column shifter hard to shift
I have an original column shifter in my 70 3/4 ton. In the morning it's
very hard to shift out of park into a gear. When the truck warms up it's alot more manageable, but by no means easy.. Whats the cause and fix? Thank you in advance
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying" |
12-15-2012, 05:46 PM | #2 | |
Sierra Grande Club
Re: Column shifter hard to shift
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
12-15-2012, 05:54 PM | #3 |
member #16
I shot a liberal amount of wd-40 on the lower column and it freed it up. Some have used in upper end also, I would try the lower end first so you don't have stuff dripping out on you.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-15-2012, 06:04 PM | #4 |
Sierra Grande Club
There's a plastic piece that wears out inside the column, and it will limit travel when you pull the lever back.
Wes at Classic Heartbeat sells all the parts you need, but requires a rebuild on the column.
12-15-2012, 06:11 PM | #5 | |
Posted via Mobile Device |
