12-15-2012, 09:02 PM | #1 |
Somehow I messed up my wipers. They won't turn on
My washer pump wasn't working, so I bought one from the junk yard. Scored what appears to be a replacement, with a date stamp of 2010. Well, got it installed, but the thing was stuck on pumping and pumping when I pushed the button to activate the washer.
Today, it was wet and snowy, so I had to use the wipers. I turned them on without activating the washer pump, but the pump just kept pumping and pumping nonstop. So, I unplugged the power to the washer pump. Now, my wipers won't turn on at all. Any ideas how to get my wipers back to working? At this point, I've given up on this pump. I'll likely find another solution, like maybe one that has the pump built in to the reservoir. I checked the fuses, and nothing is burned out Posted via Mobile Device |
12-15-2012, 10:00 PM | #2 |
The Older Generation
Re: Somehow I messed up my wipers. They won't turn on
I'm wondering if you may have pulled the wiper plug loose when you unplugged the washers, or the wire from the washer plug to the wiper plug may have broken off. I don't know if this thread will be of any help or not but you can check it out... http://67-72chevytrucks.com/vboard/s...d.php?t=413551 LockDoc
12-16-2012, 04:54 PM | #3 | |
So, how do I fix this, just take out the pump, and buy a used one of an S10 or whatever, that has the pump inside the bottle? Posted via Mobile Device |
12-16-2012, 06:06 PM | #4 |
some times you can just let it run and it will finally stop pumping....if it does stop never push the wiper knob in again....then get an after market add on bottle with pump...
12-16-2012, 07:30 PM | #5 | |
I'm guessing that when you put the new washer pump in it you put something together wrong. They look pretty simple but if you don't get the timing right on them they can do some screwy things. LockDoc
12-16-2012, 07:34 PM | #6 | |
12-16-2012, 07:38 PM | #7 |
Too involved to explain on here. Especially for a two fingered typer..... Best thing to do would be to look at another wiper assembly.
LockDoc
12-16-2012, 09:38 PM | #8 |
hope this works and helps...
CD4 Washer Pump Assembly Parking wiper motor & parts list http://nastyz28.com/tech/electrical/cd4pump.jpg well i dont think it worked ...dang Last edited by ole dollor; 12-16-2012 at 09:49 PM. |
12-16-2012, 09:43 PM | #9 |
mister-b try to copy and past the link and see if that helps. would not let me copy and past to the post..
12-16-2012, 09:48 PM | #10 |
Cluster King
Try this way.
copy the url to your browser and open it. Once the image appears on your screen, right click and save to a place you will find it. Any problems, just say so. |
12-16-2012, 09:53 PM | #11 |
thanks Tbone1964..
12-16-2012, 09:57 PM | #12 |
Cluster King
I see you figured out a way to make the link work. More than one way to skin the cat.
Happy Holidays |
12-16-2012, 10:15 PM | #13 |
and a Merry Christmas to you also Tbone
