2wd Exhaust Clearance
Just thinking out loud here. Is there enough clearance for a single 5" exhaust on the 73-87 2wd trucks? Thanks fellas.
![]() Join Date: Jul 2010
Re: 2wd Exhaust Clearance
yes & don't do it...
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
Why single? Two 2.5 pipes yield the same with better scavenge less pressure and better sound and can be quieter and yeild better ground clearance. So really not a point
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#4 | |
#5 | |
But yes for turbo get a fat downpipe in there and don't go to long Posted via Mobile Device
What turbo are you going to run?Unless its a diesel 5 inch exhaust is over kill.
It would be in the 75-85mm compressor range, lsx engine. There is a guy over on performancetrucks.net that seen a 20 lb/min increase in airflow when dumping his 5" downpipe at the 4" bottleneck in his exhaust. That's a pretty substantial increase in my opinion. That is what got me thinking about the 5" exhaust and if it would even fit under the 73-87.
How did he measure the air flow differences tho?
#9 | |
post some pics. |
