Old 12-15-2012, 09:37 PM   #1
lts70
1970 Daily Driver
lts70's Avatar
How do you decode a small block casting number - 7R1o1294 T04T4HC ???
The block numbers are
7R1o1294 T04T4HC
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is online now   Reply With Quote
Old 12-15-2012, 10:20 PM   #2
72 K20
72 K20's Avatar
Re: How do you decode a small block casting number - 7R1o1294 T04T4HC ???
Here's a thread that might help !!
http://67-72chevytrucks.com/vboard/s...29#post5731829
72 K20 is offline   Reply With Quote
Old 12-16-2012, 10:31 AM   #3
bruceman1968
bruceman1968's Avatar
Here's what I came up with so far. To be sure we need the date code and casting number off the block
7R1o1294 T04T4HC
T = Tonawanda engine assy plant N.Y.
04= april
T4- The T is wrong. This 2 didigt number is the day/date of the month april. So it could be a 0 for 04th or a 1 for 14th or a 2 for 24th.
HC = this is the engine stamp suffix code. HC was used from 65 to 69 on 350's and 327's in camaros chevelles impalas and novas. To narrow yours down we need the casting number and date off the block.
7R101294 should have a 1 at the front. 17R101294
1=chevrolet
7= 1967
R= arlington TX plant
101294= this will match the vin number of the car it came out of.
Because this motor came out of a car we have the date 1967
HC code in 1967 is a 327, 275hp, impala 4bbl, coupled to a powerglide trans.
But that's not definite. To be sure we need the date code and the casting number on the block. (see pic)
1967 pertains to the car, the date code off the motor is really the date code that will give a definite answer.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 12-16-2012, 11:51 AM   #4
lts70
1970 Daily Driver
lts70's Avatar
pics
3903352 cast #
Old 12-16-2012, 12:12 PM   #5
bruceman1968
3903352 hits for a 1967, 327 So it is the motor listed above.
If that is in fact a T, then the person that stamped it made a mistake. It happens, I've seen it before. It does look like a T. It really doesn't matter much, the HC is the code you want out of all that.
HC with casting number 3903352 is definitely a 67, 327, 275 h.p.
Old 12-16-2012, 01:35 PM   #6
lts70
1970 Daily Driver
lts70's Avatar
You are the man!!! What tells that it is an impala?
Old 12-16-2012, 02:23 PM   #7
bruceman1968
Its part of the HC code. I have a field book of small block suffix codes and the impala is listed in the book for 1967 HC coded blocks. Sometimes it's wrong but not very often.
Atleast you know it's a 67, 327.
That's a good lookin truck in your avatar.
always happy to help
Old 12-16-2012, 02:26 PM   #8
lts70
1970 Daily Driver
lts70's Avatar
Can you email me a scan of that page?
It has camel back fuely heads. Being a 275 hp motor would those be 202's?
Old 12-16-2012, 02:47 PM   #9
bruceman1968
I'm not sure about the heads.
Here is a pic of the page. The second pic shows the headings for each colum.
Old 12-16-2012, 03:01 PM   #10
lts70
1970 Daily Driver
lts70's Avatar
Thanks!
