Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-15-2012, 11:12 PM   #1
southern parts
southern parts's Avatar
tach cluster 1976 -77
pulled from a 76-77 half ton truck. 60 lb mechanical oil gauge. i`ve not tested it , but gauges appear to be in working condition. includes the harness, needs a new end on the ground wire. the housing has a few cracks and is missing the tab on the left. $150 shipped
southern parts is online now   Reply With Quote
Old 12-21-2012, 07:22 AM   #2
southern parts
Re: tach cluster 1976 -77
ttt
Old 12-30-2012, 09:17 PM   #3
southern parts
was able to check the tach , it works but reads high. new price . $120 shipped
Old 12-31-2012, 10:35 AM   #4
Duncan and son
Hey Woody we just bought a 1975 crew cab dually 454 camper special but know very little about 73-80 trucks. What is the difference between 73-75 gauge cluster and the 76-77 you have listed?
Always appreciate you , Thanks Paul and Jason
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 12-31-2012, 06:05 PM   #5
glimmertwin01
glimmertwin01's Avatar
73-75 have an Amp meter and the configuration of the plug going into the back may be different...but im nto totally sure when i put a 77 tach cluster in a 73 i had already swapped the harness for a 77. and my tach reads high too. the one in my 74 is the correct one for a 73- 75 and it is spot on...
hope that helps
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 12-31-2012, 08:57 PM   #6
80SPORT
80SPORT's Avatar
You can adapt the ammeter harness to the voltmeter cluster but it is a bit of work ...use the newer plug and splice 12 v + to the voltmeter
Often reading high can mean the tach was in a 6 cyl originally ...will work fine but 25 percent high
80SPORT is offline   Reply With Quote
Old 01-01-2013, 04:02 AM   #7
71Burb
If that is a 6 cyl tach , iam interested. Any way you can confirm? Thanks, al
Al from Calary. 72 Chev S/B Ground Up Project.
71Burb is offline   Reply With Quote
Old 01-01-2013, 10:05 AM   #8
southern parts
The truck i pulled it from is a 76-77 3/4, V-8 4spd. GMC. but that doesn`t mean someone didn`t change it out at sometime.
most of these that i`ve seen will have 8cyl stamped on the back , this one doesn`t, it has a four digit number (8775)
i`ll try to get a better pic of the tach later today.
Old 01-02-2013, 08:45 PM   #9
ray_mcavoy
I'm interested at $120 shipped if 71Burb passes on it.
I believe there is a calibration resistor in a lot of 70's GM tachs that has a tendency to change value with age and cause them to read high.
Here's a page showing how to fix 1978-up truck tachs --> http://howtoalmanac.com/kevin/projec...chfixtruck.htm I think the internal circuit on the 76-77 tachs is slightly different but still the same concept.
ray_mcavoy is offline   Reply With Quote
Old 01-02-2013, 09:33 PM   #10
southern parts
here`s a pic of the backside of the tach
Old 01-03-2013, 04:45 PM   #11
4oldcars
4oldcars's Avatar
I'll go $100
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
