Old 12-15-2012, 11:15 PM   #1
fastnloud
fastnloud's Avatar
Fixing a manual window..
On my 82 GMC Sierra the driver side window doesn't roll up and down smoothly. So, I would like to try to get to the track or whatever you call that on manual windows? and see If I can fix it.
If I take the door panel off will it be right there, or is there something else that needs to be taken off?
Thanks guys.
fastnloud is offline   Reply With Quote
Old 12-16-2012, 10:10 AM   #2
donut
donut's Avatar
Re: Fixing a manual window..
iirc, there are a couple of screws in the panel, and removal of the clip holding the window crank (and messing with the push pins holding the panel tight to the door)
You should have access to the window mechanism.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 12-16-2012, 08:02 PM   #3
fastnloud
fastnloud's Avatar
Thanks. I went out and checked it today, the driver side window crank has been put on it some kind of a weird way. I'm going to go ahead and get a new crank and clips. Wheres a good place to get these?
Old 12-16-2012, 09:00 PM   #4
krazy_texan
krazy_texan's Avatar
New clips should be at any parts store they might even have handles if not just make a trip to your local junk yard
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 12-16-2012, 09:03 PM   #5
1978chevybigten
1978chevybigten's Avatar
stay away from autozone, oreilly, etc.. handles mine broke within 3 weeks of buying them..
1978 big ten 350/350:chevy
1978chevybigten is offline   Reply With Quote
Old 12-17-2012, 09:57 PM   #6
grs
When you have the door panel off you will find sheet metal on the inside of the door. You can then spray WD40 on the window regulator. This may help it roll up and down better. There are many thing that could cause the problem. I had a window that was hard to role up and down. It turned out that the glass was to thick. Some trucks have thicker glass then others. I discovered this by accident. I got a thinner one at the yard and it works great now.
grs is offline   Reply With Quote
Old 12-17-2012, 10:03 PM   #7
fastnloud
fastnloud's Avatar
Thanks guys, on my driver side window crank I don't see any clips. It almost looks like someone wired the crank on there somehow, I'm not sure if I need to buy new clips and washers or what.
Old 12-18-2012, 10:49 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
yes the older glass is thicker
is the handle plastic ,might be stripped
a trick showed here is to drag a clean rag behind the crank catching the C clip
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-18-2012, 12:04 PM   #9
Desert1957
Desert1957's Avatar
Here is a pic of one style of tool needed
Desert
Desert1957 is offline   Reply With Quote
Old 12-18-2012, 08:05 PM   #10
fastnloud
fastnloud's Avatar
Thanks guys for the help. As of today, the driver side window is stuck rolled all the way up. I didn't want put a whole lot of force in to seeing if it would come back down. I'm going to get one of those tools like above and remove the crank and door panel and see whats going on. Should I be able to pick up one of those window crank removal tools at a NAPA?
Old 12-18-2012, 08:28 PM   #11
donut
donut's Avatar
You used to be able to, haven't shopped for one lately. They should also sell like a 5 pack of clips for the window crank for a couple bucks. Couple bucks well spent if the old clip goes "zing".
Old 12-18-2012, 11:39 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
John
Old 12-19-2012, 12:32 AM   #13
fastnloud
fastnloud's Avatar
Thanks. I'm also missing the washer on the driver side crank. Do they just need one thin rubber washer?
Old 12-19-2012, 12:40 AM   #14
INSIDIOUS '86
INSIDIOUS '86's Avatar
The Escoution? It's the plastic washer
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-19-2012, 12:44 AM   #15
fastnloud
fastnloud's Avatar
Alright yeah, that's what i was talking about. Thanks.
Old 12-19-2012, 12:51 AM   #16
INSIDIOUS '86
Lmc should sell them otherwise a wrecking yard is a good place.
I would tell my freinds my truck was always faster cause I had two escoutions haha
Old 12-19-2012, 01:03 AM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
There is a foam bit over the shaft, and the round plastic washer
John
Old 01-02-2013, 12:10 AM   #18
fastnloud
fastnloud's Avatar
I have decided I need a window regulator. I ordered one, how hard is it to install a manual window regulator on these trucks? Can I do it with just basic hand tools?
Old 01-02-2013, 01:18 AM   #19
KQQL IT
At the body shop.
KQQL IT's Avatar
Patience will be the best tool.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 01-02-2013, 08:43 AM   #20
motornut
78K & 79C Jimmys
motornut's Avatar
once the panel is off
four bolts,push into door,slide off tracks(note postion)
John
Old 01-02-2013, 11:59 PM   #21
fastnloud
fastnloud's Avatar
Alright thanks. I will not have to remove the window glass, right?
Old 01-03-2013, 10:30 AM   #22
motornut
78K & 79C Jimmys
motornut's Avatar
have to drop it a bit,but i have used tape/bent coat hanger, to hold it up
John
Old 01-14-2013, 08:49 PM   #23
fastnloud
fastnloud's Avatar
Well, I tried to take out the old regulator yesterday, couldn't get it.
Do you have to remove the vent window on this body style? I can't get the regulator out, because the shaft that the window crank goes on doesn't have enough room to be pushed back, and slid out. It hits a metal bar, that seems to be attached to the vent window.
Old 01-14-2013, 09:12 PM   #24
motornut
78K & 79C Jimmys
motornut's Avatar
there is a wheel that rolls in a track on the door
you have to get it out of there
John
Old 01-14-2013, 09:19 PM   #25
fastnloud
fastnloud's Avatar
Yeah, I was trying that, but with the shaft part still sticking through the inner door, I couldn't get enough play in it to get any of the wheels off the tracks.
I'm not sure what I'm doing wrong.
