Old 12-16-2012, 09:18 AM   #1
Baggerjohn
Baggerjohn's Avatar
A little help please.
I have a 67 lwb C-10 with a 292, 5 speed. I don't have back up lights. I tested the switch on the trans and it's good. There are no wires from the switch to the tail lights. Can anyone please tell me what I need to get to have them operational. Thanks.
Another question is that with the 292 and 5 speed, single carb, I get terrible mileage. I don't have a speedometer but I use my old gps for speed. I notice at 2500 rpm, I'm going 68 mph in 5th gear. That sounds great but if I go 20 miles, it goes through a quarter tank. That ain't right. Any suggestions on what I can do to improve mileage? I don't have a camper or haul anything. Any help is appreciated.
"Arrive, Raise Hell, Create Confusion, Leave".
Baggerjohn is offline   Reply With Quote
Old 12-16-2012, 10:15 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: A little help please.
In my 68 the backup switch is in the steering column. Check the cables from the there to the firewall and back to the tail lights. If it's been rewired you can buy a tail light wiring kit from vendors on this site. I had to rewire mine at the back of the bed since the previous owner had cut and spliced for trailer towing.
forgot: re. gas mileage. Going by fuel gauge may not be the best way. Fuel gauges are not very accurate indicators. It's probably a good idea to check exactly what mpg you get the next time you take a long highway speed trip. Fill up the tank and either with the gps or another vehicle check the mileage you travel and refill the gas tank afterwards to see exactly how much gas you used. Do this a few times to get a better average.
Things to look for is choke adjustment, timing, ignition components like plug and points, and/or take the carb apart and rebuild it.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
