Old 06-06-2003, 02:33 PM   #1
694X4
694X4's Avatar
Np205 Pto Question
How does it work? say i have a winch on the back bumper and I am stuck do i put the x-case in N and the trans in gear then give it gas? Or do I have to be moving for it to work. It was on my 72 gmc 3/4 ton 4x4 with a th350.
69 3/4 ton 4x4 gmc with 6" sky jacker soft ride. 350 / th350 / 205
work in progress
694X4 is offline   Reply With Quote
Old 06-06-2003, 04:30 PM   #2
Mike C
Mike C's Avatar
The PTO should have its own shifter that engages and disengages. You then can leave trans in neutural, shift PTO to engaged. They are unsynchronized, so it may be best to shut it off, engage the pto, then fire it back up.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-06-2003, 04:34 PM   #3
694X4
694X4's Avatar
It is on the transfer case so i guess i put the trans in 1st and then leave the transfer in N then engage the pto?
work in progress
Old 06-06-2003, 06:05 PM   #4
72addict
Correct 694x4
1957 Cameo
72addict is offline   Reply With Quote
