Old 12-16-2012, 04:50 PM   #1
1986brownjl
383 stroker help
i have a 383 stroker that i want to rebuild. and i have a 86 chevy k10 that i want to put it in and i was looking to making around 400 to 450 hp and torque. anybody have any suggestions?
1986brownjl is offline   Reply With Quote
Old 12-16-2012, 05:16 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: 383 stroker help
If your on a budget vortec heads will be the best thing to put on. Get the vortec intake and call comp cams with engine specs and your use and they will match you with a cam to get you there. Don't go more than half inch lift since after about 480 lift the vortecs start tumbling the air. This would make a roller cam more relevant for your build
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-17-2012, 12:25 PM   #3
manimal
manimal's Avatar
If you use a later model block, loo for the bosses in the lifter valley, they will be HYD roller cam compatible,1 pc rear seal. You can get a SCAT or EAGLE crank for it and build a nice 383. Used Vortec heads? Im not feelin it. a lot of them crack,then they need work to accommodate larger lift cams. Check out Summit Racing's Vortec heads, your power levels are very easily achievable.....1 more thing, YOU DONT NEED A 4blt block either.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
