Stock radio. How much does it cover the dash knob holes?
I removed the non working cheesy aftermarket radio from my truck. I was a little ticked to see that they slightly ground the inside edges of both knob holes to get it to fit. They didn't do much. Maybe less than a quarter inch. It still has a piece in tactic each side between the main stereo opening.
I'm looking at buying a stock AM GM radio, but I'm wondering how far the knobs overlap the holes, in hopes that it might cover up the part they cut? If not, has anybody found a good gasket, washer, etc. that would look good? Posted via Mobile Device |
Re: Stock radio. How much does it cover the dash knob holes?
The stock radio uses a bucket type washer on the face side of the dash that the shaft nuts tighten down on sucking the radio into the dash. Not too sure how much of a flange there is, want to say about .125" or so. Think the tone and dummy are pretty much the same size (OD) as well. Might try looking through the classifieds for radio pictures to see this.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 12-16-2012 at 05:53 PM. Reason: added pic |
#3 | |
Active Member
![]() Join Date: Jul 2007
I show them to be 1-3/16th total diameter for the wide part. The narrow part that fits in the hole is 1-1/16th. The knobs are 1-9/16th.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Active Member
Correction on above... I meant the large chrome rings not the knobs.
