12-16-2012, 11:02 PM | #1 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
CPP tubular control arms
anyone know if the CPP tubular control arms re-position the front wheel to center it more in the wheel well like the Porterbuilts? or do they just offer better alignment geometry than stock??
12-17-2012, 09:34 AM | #2 |
Re: CPP tubular control arms
I've never read any info about CPP's arms changing the wheelbase.
12-17-2012, 10:45 AM | #3 |
It's my understanding that they just provide better alignment geometry. I'm getting ready to install a set (coils not bags) and will let you know.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-17-2012, 11:24 AM | #4 |
thanks Hart Rod....was considering the Porterbuilts for improved geometry and centering of the wheel in the wheel well but the CPP are more economical if they do the same thing? havent heard any hype about it on the CPP side so I'm asuming they dont but thought I pop the question anyway and see what shakes out....keep me posted on the arms if you can?
12-17-2012, 11:53 AM | #5 | |
12-17-2012, 12:11 PM | #6 |
As far as I am aware, we are the only company building arms that locate the lower ball joint "forward" for improved performance and aestetics. For now anyways.
The CPP arms also use a solid style bushing... I don't believe it is delrin, but a similar material. They are a nice product.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
12-17-2012, 01:37 PM | #7 |
Nate - do you have to change upper and lower to do the 1" forward mod? Can you do 63-70 balljoints?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
12-17-2012, 01:47 PM | #8 |
Hotchkis arms also move the wheels forward. Lots more $$$ though.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-17-2012, 03:08 PM | #9 | |
If it is more of the aestetic centering of the wheel that is desired, then the uppers combined with the lowers will give the best result. 63-70 ball joints are no problem.
12-17-2012, 05:24 PM | #10 |
Yes, definitely wanting to center the wheel for improved aesthetics.....some of our trucks seem to be more noticeable than others and likely mine will be noticeable with a 5.5/7 static drop....so if the Porterbuilt upper and lower arms together move the wheel forward in the wheel well effectively 1", how much does just the lower alone move it....is it 1/2", 3/4", 1/4"....any idea?
the PB lowers come complete with year specific (67-70 or 71 & 2) ball joints correct? what type of sway bar can be used....does it require changing to an end link style? |
12-17-2012, 06:31 PM | #11 | |
We can also build them where the upper AND lower are moved forward 1". This moves the wheel the whole inch forward. This configuration doesn't get the same castor gain. If we do the lowers only, it will move the wheel forward right between 1/2" and 3/4". Here's a pic of the upper and lower forward arm combo (factory x-member with bags)
12-18-2012, 06:49 PM | #12 |
So the arms on "Picacho" are both moved forward 1"? Uppers 1" and lowers 1"?
