12-17-2012, 04:41 PM | #1 |
CPP Brake Kits
Anyone got a build thread on this brake kit, and does anyone know what the minimum size rim are needed with these, I nave 15s... thanks
http://www.classicperform.com/Store/.../6366cbk-6.htm
OKLAHOMA MEMBER MEET JUNE 15, MIDWEST CITY OK.http://67-72chevytrucks.com/vboard/s...d.php?t=559886 72 C-20 Stepside - Work In Progress |
12-17-2012, 05:37 PM | #2 |
Re: CCP Brake Kits
That uses a 12" rotor I believe, which will be fine with most 15" wheels. Original drum brake wheels will not work, due to the shape of the outer rim. Most aftermarket 15" wheels and stock 15" wheels used on disc brake applications will work.
The stock drum brake 15" wheels will work, but will have to use a .25" spacer or more so they clear the caliper. I have heard with a .25" spacer, some minor grinding will need to be done to the caliper still. I am thinking just a slightly larger spacer will keep you from grinding the caliper. - Travis |
12-17-2012, 05:42 PM | #3 |
Re: CCP Brake Kits
Thanks, mine are aftermarket so i am sure they will be fine...
12-17-2012, 06:26 PM | #4 |
Re: CCP Brake Kits
Yeah, I think you will be good.
We are a CPP dealer, so if you haven't purchased, let me know. Travis |
