Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 12-17-2012, 05:00 PM   #1
GMCNUT
GMCNUT's Avatar
64-66 Original paint, bondo free Driver's Door
I have a pretty decent Drivers side 64-66 door - 100% complete, regulator works, inner panel in tact, etc. Is an old original farm truck door so it has all kinds of ancient farm related stickers on it from the 60's or whatever, but its never been painted or messed with, and has never been opened too far, etc
Had big mirrors on it and the mirror got bumped at some point so the outside skin has minor indentations where the mirror mounts were, but should pop out easily enough. The bottom has surface rust mostly, but does not need a door bottom in my body mans' opinion - just needs some welding work at each corner and on the one outside corner where its cracked. I have more pictures if you need them - good door compared to a lot I see here in Sweet Home Alabama....
only 125.00 first come first served
GMCNUT is offline   Reply With Quote
Old 12-17-2012, 05:05 PM   #2
GMCNUT
GMCNUT's Avatar
Re: 64-66 Original paint, bondo free Driver's Door
Forgot to say - this is for local pickup here in North Alabama or I can deliver to Nashville TN Feb 2nd or anywhere along the I-65 corridor between N Alabama and Indiana in the May/June timeframe when I come up there. Otherwise, this door can ship COD on Greyhound to wherever you are - go to www.shipgreyhound.com to figure any rates you want to know - I do not know the weight or longest dimension so come up with that off your existing doors, and use Huntsville AL 35801 as the sending GPX station - this will figure your rate. Thanks
