12-17-2012, 05:18 PM | #1 |
Too many keys
I’ve got three different squares and six different keys. Always one to simplify, I’d like to key all three trucks the same. Anyone know where a feller could pick up three ignition cylinders and a half dozen door cylinders that are all keyed the same, or do I need to go to a Locksmith for this?
12-17-2012, 05:55 PM | #2 |
Moderator
Re: Too many keys
Take the cores to a locksmith, he should be able to "recode" them. It's a much newer vehicle, but I recently had an issue with my wife's 2009 Suburban and in lieu of paying an exhorbitant amount to fix it I learned how to recode the cylinder which is basically just swapping numbered tumblers.
I doubt that a retailer who sells the matched sets knows how to get three of the same sets. And thank you for the great idea! How cool would it by if my 1950, 1971 and 1987 were all keyed the same?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
12-17-2012, 05:55 PM | #3 |
Re: Too many keys
Might just be easier to have you main key ring, with your house, mailbox, and whatever other keys on it. Then, for each truck make a key ring with all the keys associated with that vehicle. Use a carabiner or linking key chain on your main key ring, and attach whatever vehicle ring you will be taking at that time. Should keep some of the clutter down in your pocket.
I'm sure this isn't what you are looking for but it's a simple answer to what sounds like a pretty expensive and time consuming task.
1977 GMC Sierra Grande |
12-17-2012, 07:40 PM | #4 |
Re: Too many keys
Find someone(s) with a CUCV military truck and swap with them. All CUCVs were keyed the same so you could find 3 different people and as long as they hadn't be change previously you should end up with 3 identical sets. Of course would be best if they were local so you could confirm.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
12-17-2012, 08:04 PM | #5 |
I know the pieces fit
Re: Too many keys
I had to replace the rear window crank and lock cylinder in my 79 Blazer and wanted it keyed to my doors. I can't remember what the locksmith charged, but it was less than $20 for the one cylinder. That could add up over three trucks but it can be done. I have a separate keychain for each car with a house key on each. I can't stand a wad of keys in my pocket, I just grab keys to what I want to drive.
12-17-2012, 11:37 PM | #6 |
Re: Too many keys
I leave the keys for each of my vehicles in the vehicles........they each have the house key, mailbox keys and possibly toolbox keys if there are any. I don't carry a whole set of keys with every vehicle key on it.
Nothing worse than jumping in a different vehicle to go for a drive to town and I can't get the mail because I don't have a key. But I do like the idea of similar keyed vehicles! Especially if they are similar vehicles that would have the same style keys! |
12-18-2012, 12:06 AM | #7 |
GoatLube Experss
Re: Too many keys
I plan to do the same thing with 3 of my truck's and 2 of the car's, but have'nt look'd into it yet.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
12-18-2012, 12:45 AM | #8 |
Re: Too many keys
I plan on re-keying my K20 and Malibu to the same this spring.
12-18-2012, 10:23 AM | #9 |
78K & 79C Jimmys
Re: Too many keys
way too many keys
I carry a small set of both trucks and both cars in my pocket hooks to larger with 3 auto starts,+ work keys and it hooks to a neck strap handle I looked into it and it was about 20 per lock then a friend who runs his shop with cube vans, said he it was easier to use them till keys were lost and people quit then stuff went missing over night,and one was stolen,drivin and abandoned (out of gas)using keys he quietly changed them back to seperates
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
12-18-2012, 11:10 AM | #10 |
Re: Too many keys
Classic Industries (I think its them anyway) sells a kit to make your doors and your ignition the same key. You might want to check that out, you could probably get blank ignition cylinders too.
Just a thought.
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
12-22-2012, 02:12 PM | #11 |
Re: Too many keys
Door locks can be keyed to the ignition key (one truck, one key). If you buy door locks at the dealership, you have the option of pre-keyed, or blanks, and they'll wafer it to your exisiting key.
You will need to see a locksmith if you want the ignition keys to be the same, and at the same time, you can get the doors keyed to the same key. "E" blanks where common between the two back when I got mine. Probably still the case since my last generic door lock set from Napa was also on an E blank. Alex. |
12-23-2012, 10:21 AM | #12 |
Cruzin
Re: Too many keys
yea i just have a key ring for every vehicle
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
