12-17-2012, 06:54 PM | #1 |
Disc brake kit question
i bought a 5 lug conversion kit from ECE awhile back. I really don't know why I went with 5 lugs. I can't change the rear to 5 lug right now. I was thinking i could just buy some 6 lug rotors and go back to 6 lugs. That way my wheels will match again. Anyone know what year to buy?
12-17-2012, 06:58 PM | #2 |
67-72 parts collector,…
Re: Disc brake kit question
ECE sells 6-lug rotors.
Contact them.
12-17-2012, 07:10 PM | #3 |
yeah i just did that. I know the 5 lugs were off of 71-87 trucks I believe. They responded that I can buy the 6 lugs from them for $79 each. I was hoping for something I could get locally.
12-17-2012, 07:14 PM | #4 |
Since there are no used factory 6-lug 4x2 rotors that are a direct fit I am aware of it seems to me a used 5-lug rear would be the cheaper solution.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-17-2012, 07:18 PM | #5 |
Prestige Worldwide
A while back I bought some dropped front springs for a big block truck, then decided to go with a small block. I called ECE to order the small block springs and was telling them how I changed my mind and he just swapped out the springs for me, all it cost me was freight. |
12-17-2012, 07:24 PM | #6 |
Cluster King
Another thought,
If you really like 5 lug for the flexibility of wheel selection you can put 5 lug axles in your rear end. You will need to buy drums also. Not sure if this will help you but I thought I would mention it. |
12-17-2012, 07:39 PM | #7 |
New rear axles, or a 71 or later whole rear end, or drilling out the 6 lug rear axle with a 5 lug pattern are all rear options, but the cheapest is still expensive. I was thinking 2 rotors would be about 70$ pair, but I guess not.
Posted via Mobile Device |
12-17-2012, 07:42 PM | #8 |
Once you buy new rear axles you still have to do something about the rear brakes. I now think buying 5 lug was stupid. I haven't seen any wheels I like that aren't available in 6 lug.
12-17-2012, 08:57 PM | #9 |
I personally like the 5-lug wheel options better.
The 6-lug rotor you need is an aftermarket item. (5-lug blank rotor drilled to the 6-lug pattern) If it was my truck,... I would add a set of 5-lug Moser axles, and some 71-72 brake drums.
12-17-2012, 09:18 PM | #10 |
At some point I'm sure I'll either do that or swap to rear disc. It's a matter of money. So who knows when it will be.
12-18-2012, 02:30 AM | #11 |
Moser axles are $260. 5 lug drums are all that is needed as mentioned above. Dirt cheap. And I wouldn't worry about disc in the rear unless you have wheels that readily show the ugly drums. Rear brakes only supply 25% of braking power in an unloaded pickup.... at best.
12-18-2012, 11:36 AM | #12 |
Pm sent
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
12-18-2012, 11:52 AM | #13 |
I'm assuming you bought the 5 lug kit because of disc brakes, correct? There was no mistake in that, much better stopping.
Like other's have mentioned your options are limited. I'm running the 6 lug rotors from ECE on my truck. I've had them since 2002 and probably over 30-35K miles on them. They seem to be a high quality rotor. ECE also sells the correct axle shafts to convert your stock rear axle to a 5 lug rear axle for around $300. As mentioned above, you can get a used 71/72 axle, but at least in my area they sell for at least $150-250 for a good one. If you really want to stay 6 lug buy the rotors.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
