Fuel gauge problems
My fuel gauge was working fine and then it started going up way above full and when you shut the motor it settles about the 1/8th of a tank mark. if any one has seen this before I would sure appreciate some help thank you, s wells
![]() Join Date: Nov 2012
Re: Fuel gauge problems
Have you checked the sending unit for continuity? How about the ground wire?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
78K & 79C Jimmys
going over full .....check ground@ back or cluster
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Moderator
![]() Join Date: Oct 2008
Suddenly pegging the gauge at 3:00 is usually the frame to sender ring ground at the tank.
It could be a break in the sender wire too. Early dual tanks could have a bad or unplugged dash switch.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Hmm,must check my fuel gauge also,shows about 1/4 with full tank.
Chevrolet Cheyenne K2500HD 1992.350tbi.4L80E. GMC Sierra Custom C1500 1983. Oldsmobile Dynamic 88 -65. Volvo V70 -02 and BMW 523i T -99. Harley FXDF -08 and Harley FXDB -10. Honda Dirtbike Dominator -97 and a couple of tractors. |
#6 | |
Moderator
If it's moving from E to 1/4 then the gauge or the calibration resistor are usually bad. If it's not moving then check the power and ground connections to the cluster plug, the plastic printed circuit, and the connection from the printed circuit to the spring clips. I keep intending to do a writeup on testing the gauges. Maybe over my Christmas holiday... Youtube sounds easier.
Thanx for info,should check that.(when it,s warmer outside)
my ground is OK at the tank but the power wire is 5 different wires.I patched it up for a temp fix but I am going to cut the bundles and run a new wire. just patching the power wire helped it reads correctly now
Scott wells 1973 k10 81 7.2l power-train ![]() |
#9 | |
thanks for all the information guys. kent. |
my gauge and sending unit are shot I am going to put an after market gauge in thanks for all the help
Have replaced the fuel gauge now and it looks better
