292 engine temp sending unit
I have a 1967 GMC with a 292 engine. Cannot find the temp sending unit. There is a wire going to the front of the engine that is not hooked up. I read that the temp sending unit on the 292 was located in the lower part of the thermostat housing, however, there is a nipple located there with one of the heater hoses connected to it. Can someone provide information or diagram as to how the heater hoses and the temp sending unit are set up on the 292 engines? Would appreciate any help or comments.
Cluster King
![]() Join Date: Nov 2012
Re: 292 engine temp sending unit
On my 64 -292, the temp sending unit is threaded into the front of the cylinder head right behind the thermostat housing. I am the 2nd owner of the truck so I think it may be correct. The wire you are referring to should be green in color.
As far as the heater hoses, the 3/4 one goes to the water pump and the 5/8 should go to the thermostat housing. |
Thanks. I previously checked the head but did not find a place for it. Will check again to make sure.
