12-17-2012, 11:24 PM | #1 |
Parts from parting a 1972 Chevy C20
I disassembled a 72 Chevy C20 that I have had. The chassis is sold, cab and doghouse is very rusty and it did not have a bed. Here are most of the parts I saved from parting it out. The cab and left front fender are available for patch panel cuts but there is more bad than good. The truck was a running and driving truck until the engine stated knocking. All parts are used. Just ask if you want more pictures. Post to thread before PM as per rules.
All prices are plus shipping unless stated different 1. Cab patch panels $20.00 and up 2. Right front fender needs front inner cup repair $30.00 NO SHIPPING 3. Automatic brake pedal SOLD 4. Heater box- inside and has floor vent attached to it $18.00 5. Ashtray and bracket $10.00 6. Cig. lighter - element is not original $5.00 7. Coat hook $4.00 8. Sunvisors SOLD 9. Sunvisor clips SOLD 10. Cab vent $5.00 11. Door latch- body side $15.00 pair 12. Clutch delete plate $10.00 13. Washer tank bracket $4.00 14. Ignition switch with key SOLD 15. Kick panel vents with handles SOLD 16. Parking brake pedal $10.00 17. Dash harness with fuse box. truck had gauge cluster and no a/c, only issue I see is the brake light switch connector has 1 lock tab broken $25.00 18. Gas pedal, cable, bracket and the stud that attaches to the carb. SOLD 19. Small block oil dipstick & tube $5.00 20. Oil gauge metal line from engine to gauge SOLD 21. Modulator vacuum tube for th350 SOLD 22. Automatic shift linkage set up- rod from column down, pivot bracket, frame bracket, bracket attached to transmission SOLD 23. Steering column trim $5.00 24. Detent cable bracket SOLD 25. Heater box that attaches to the inside of the firewall- plastic with rubber seal $20.00 26. Wiper arms $10.00 pair 27. Wiper linkage $5.00 pair 28. Defrost vents- aftermarket black, installed a short time $10.00 pair 29. Glove box door - was blue but painted flat black but taped off the tag $15.00 30. Pair of 1972 doors - good over all condition- left side cracked at upped hinge, right side has hole on the inside bottom. some dents/ holes, with aftermarket outer mirrors SOLD --Extra--72 door screw from another truck and 69 roller ashtray from another truck are also SOLD Thanks for looking and ask any questions you might have and let me know if you want better pictures. Thanks
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. Last edited by Todd68Chevy; 01-08-2013 at 08:47 AM. Reason: items sold |
12-17-2012, 11:29 PM | #2 |
Re: Parts from parting a 1972 Chevy C20
More pictures
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
12-17-2012, 11:32 PM | #3 |
Ill take the door screws if available and any chance you have the alternator brackets available. Shipped to 93013
Posted via Mobile Device |
12-17-2012, 11:35 PM | #4 |
door pictures
12-17-2012, 11:39 PM | #5 | |
More door pictures
12-17-2012, 11:53 PM | #6 |
So,, what else you got???
Some real good deals there Todd...
12-19-2012, 09:10 PM | #7 |
I have this pair of screws and spacers out of another 72. I wire wheeled them off and they look pretty good but one spacer has a small hole at the base that would be in the door (seen in picture 2). $15.00 shipped USPS Priority Mail or $12.29 shipped USPS First Class Mail. Let me know. Thanks
12-19-2012, 09:12 PM | #8 |
Thanks, I am hoping they are. LOL
12-19-2012, 10:09 PM | #9 |
Does the gas pedal parts come with the bracket that would go on the carb with kickdown?
12-19-2012, 10:30 PM | #10 |
The bracket that I am including is just for the throttle cable bracket I think. I do have a detent cable bracket that bolts to the intake I will include if you want it. I can get better pictures but here are the ones I have. Thanks
12-19-2012, 10:41 PM | #11 |
Those pictures work great for me, were you looking for $45 shipped for the ride up to MI for all pieces? If so, I will take it
Its been a few years since I had a 72, does the throttle bracket go under the carb stud? |
12-19-2012, 10:52 PM | #12 | |
I did not remove either bracket so I am not sure where they were mounted. I might be able to find out. Thanks
12-19-2012, 10:55 PM | #13 |
Sounds good, my zip is 49323. Let me know what you come up with, thanks again
12-19-2012, 11:01 PM | #14 |
"Ignition switch with key $10.00"
Could you throw in the matching door locks and go $15.00 shipped? |
12-19-2012, 11:56 PM | #15 |
I was planning on keeping the doors together but I guess it would make more since to include the locks with the ignition. I would pull the door locks out and go $20.00 plus shipping for the ignition, both door locks and the keys if you are interested but I can not go 15.00 shipped. Sorry but let me know if you are still interested. Thanks
12-20-2012, 12:36 AM | #16 |
Would go $20 shipped if they all function as they should.
12-20-2012, 12:47 AM | #17 |
I need the jack handle price + shipping to 75142
Thanks Rickey |
12-20-2012, 02:45 AM | #18 |
Todd If you still have the doors I'll look at those when we get the frame.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
12-20-2012, 09:13 AM | #19 | ||
I have a meeting after work tonight but should be able to figure it when I get home. Thanks Sounds good Chuck
12-20-2012, 11:30 AM | #20 |
just the lock cylinder part for the ignition...should all fir in a small flat rate box, my zip is 92557.
Thanks |
12-20-2012, 07:12 PM | #21 |
Is the Modulator vacuum tube in good shape, any kinks, and dose it have the tab on it where it bolt to the bell housing? Can you post a better picture of it?
I am interested in the ash tray and bracket. Would you separate the door panels with arm rest? If so how much shipped to 77339 for all? |
12-20-2012, 07:18 PM | #22 |
Is the ashtray still available? If so I will take it.... Thanks Projectjimmie
12-20-2012, 11:02 PM | #23 | |||
$5.00 plus shipping but it will be tomorrow night before I can figure that and get better pictures, Thanks Quote:
This one might be sold but I have other ones. Do you need blue or just an ashtray? I think I have another blue one. I will check tomorrow night or Saturday. Thanks
12-21-2012, 03:13 AM | #24 |
Blue would be fine if you have one. Price shipped to zip 32136...Thanks Projectjimmie
12-21-2012, 09:21 AM | #25 |
I am looking for door panels that style and that color in very good shape,those looked pretty good. I will take the ashtray / bracket and the Modulator vacuum tube. PM me your payment information
