Old 12-18-2012, 01:05 AM   #1
Jmageee902004
Wiring engs
I was wondering were i can get wire ends for rewiring my truck. Im making my own harness and need the female tips that connect to the male end of the fuse box. What was used before by the previous owner were black square plastic pieces but i couldn't figure out how to reuse them.
What are you using if you did your own harness? im trying to avoid the the cheap quick connect standard unprotected terminal type. and all the hard plastic ones i see have preset wires in them so i would have to crimp them together somewhere else down the line.
Also how does one go about testing the alternator? i drove my truck around for about 10 minutes and when i got back home, and tried to start it again the battery didnt have enough juice to turn the starter over.
Jmageee902004 is offline   Reply With Quote
Old 12-18-2012, 01:19 AM   #2
Amorget
Re: Wiring engs
For wiring up I'd buy a kit like this:
http://www.summitracing.com/parts/ce...5/media/images
It's what the OEM uses for connections (at least GM).
I'm not sure what the connectors to the fuse box look like, though... sorry.
Amorget is offline   Reply With Quote
Old 12-18-2012, 01:24 AM   #3
Daner
Daner's Avatar
Re: Wiring engs
Bring one of the connectors in to NAPA. They have or can get most of them seems like.
Here is a good video that shows how to test your alternator. Easier to understand than me typing it all out.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 12-18-2012, 10:41 AM   #4
Nordic
Nordic's Avatar
Re: Wiring engs
Here is a link for connectors. I used these and fab all my harnesses
http://www.classicparts.com/Connectors/products/937/
Nordic is offline   Reply With Quote
