Old 12-18-2012, 02:00 AM   #1
jrblanke
Spent some time with the new '85 today, including a shakedown trip
I took the bug sheild, bumper stickers, and kenco running boards off the truck today, then drove the truck 32 miles to work. The drive was kind of a shake down trip to learn more about it's over all condition. What stuff worked, what stuff didn't work, any strange noises, etc.
The radio works pretty good. Freebird came on the radio, that was awesome. The drivers side mirror is a little loose which created a really annoying vibration at idle. Not really a big deal.
The only disturbing thing I found (besides a loose mirror), was this horrindous noise that seemed to come from the front of the transmission hump in the floor. It sounded like a grinding...WWHAAAGGGGGGG. It only happened when I was sitting still and nailed the gas. It seemed to be more violent when I had the wheel turned to take a 90 degree turn. At first I thought it was torque converter/transmission related, but now I am thinking that it is a loose motor mount or transmission mount that is allowing something to touch something else when it shouldn't. I am going to do some looking tomorrow to see if my fan has been hitting the shroud or the drive shaft hitting something.
I will update tomorrow night with what I find
jrblanke is offline   Reply With Quote
Old 12-18-2012, 02:19 AM   #2
bk2life
Re: Spent some time with the new '85 today, including a shakedown trip
power steering pump whine?
bk2life is offline   Reply With Quote
Old 12-18-2012, 03:26 AM   #3
jrblanke
I'll definitely check the fluid on that tomorrow, but I don't believe it is the power steering. My '73 corvette has made the power steering pump whine before, and this noise from the truck is different from that (same type pumps).
Thanks,
James
Old 12-18-2012, 09:51 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
or use a broom stick to your ear...helps find a bad air pump
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-18-2012, 06:08 PM   #5
jrblanke
Here are the pictures after removing the running boards and bug sheild.
I didn't get the chance to do much investigating today. I looked under the truck at the U joints and motor mounts and trans mount but I didn't see anything obviously wrong. I believe I am going to have to get a second person to help me out. I will plan to do that over Christmas.
Old 12-18-2012, 07:16 PM   #6
68Timber
I know the pieces fit
68Timber's Avatar
It sure is a good looking truck. Good luck finding the noise.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-18-2012, 07:17 PM   #7
LEEVON
Moderator
LEEVON's Avatar
Gotta love the white knuckle shakedown run. Then Freebird comes on a it's like your in some sort of alternate 80's universe/paradise.
I think I might have already said it, but sweet truck!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-18-2012, 11:41 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
nice,
John
Old 12-18-2012, 11:57 PM   #9
INSIDIOUS '86
INSIDIOUS '86's Avatar
Man I wish I had those bed rails. Nice truck for sure!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-19-2012, 01:05 AM   #10
Low84
Low84's Avatar
Nice truck and good luck tracking the problem
I don't know what I've become more addicted to negotiating prices on old vehicles or the adrenaline rush of driving the darn things back scared out of my mind. Last one had a bad transmission that would disengage the shifter from the transmission and had to be started with a screwdriver. The other one turned off on me twice and I was still able to get both home under their own power
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 12-28-2012, 06:32 PM   #11
jrblanke
I was able to identify that awful grinding/binding noise is coming from the radiator cooling fan hitting the plastic fan shroud. I know this because I was showing my neighbor the problem and when I nailed the gas hard enough, the fan took off enough of the plastic shroud that it was still hitting slightly when the engine was at idle.
I got under the truck and replaced the transmission mount which appeared to be broken. I did not replace the motor mount, but I believe the drivers side is broken. I am not going to drive the truck anymore until I replace that motor mount (or I am just going to end up with another broken transmission mount.
Must have been all the frame twisting torque from the 155 horse power 4.3L V6
In other news, I believe the front left brake line has collapsed. When I tried bleeding the brakes, barely any fluid came out of the bleeder. The bleeder and caliper are not rusty and appear to be new (previous owner said he replaced the caliper a week before I purchased the truck from him).
Old 12-29-2012, 03:51 AM   #12
LEEVON
Moderator
LEEVON's Avatar
I broke a 4.3L motor mount once, although it was more from wreckless tomfoolery than torque. My Dad had a '92 Silverado with the 4.3L and NV3500. You could put that trans in the super low 1st gear, stomp on the gas and it would roar to redline, travel about 20' (literally, the gear was stupid low) then the fun would come when you grabbed 2nd. Then one day "out of the blue" the fan started hitting the shroud...
Dad, if you ever happen read this I'm sorry and at least I never burned up the clutch!
Old 12-29-2012, 06:31 AM   #13
bbbc10
Diggin The SquareLife
looks good....i still need to find some bedrails like that
bbbc10 is offline   Reply With Quote
Old 12-29-2012, 12:23 PM   #14
Joesjunk
Joesjunk's Avatar
Great looking truck!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 12-30-2012, 12:39 AM   #15
silvereagle07
silvereagle07's Avatar
Looking good jrblanke! What's next in the plans?
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-05-2013, 12:14 AM   #16
jrblanke
Finally got around to working on the truck. The trans mount was cracked, and the drivers side mount was pretty wasted.
So as it ends up, the crazy noise was the metal fan hitting the shroud.
Silvereagle,
After having a few months to drive and evaluate it, I have decided that I am going to sell it. I know there were lots of these trucks made, but I still can't bring myself to molest such an original truck. I have an 84 silverado that I was working on before buying the blue truck and I think I am just going to continue to work on it. It is a great little truck that putts around town with ease, but the more I drove it the more I wanted to get the V8 silverado back on the road. Can't have both trucks.
Old 03-05-2013, 08:29 AM   #17
Keith Seymore
Keith Seymore's Avatar
That, or the fact that the shroud is a mile long...
(lol)
Nice truck - good luck with it.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-05-2013, 11:40 PM   #18
jrblanke
That shroud is pretty crazy! I feel like I could remove it, put some handles, a bottom, and a wheel on it and have a great wheel barrow.
