New exhaust and lowering
Hey guys, I'm going to install a new exhaust system (I have nothing from the manifolds back right now), but I also want to lower my truck.
Do I need to lower it first? Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
Eddie ![]() A lonely DODGERS fan in a sea of orange and black 1963 GMC Project 1997 Silverado 4X4 |
Re: New exhaust and lowering
Depends how low is low for you. some think low is two inches. if thats the case, No you dont have to lower your truck first to add new exhaust system.
BUT. If low to you means layin on your frame, you might want to lower it first so you run your new exhaust system to where it wont be on the ground.. when is comes to posts here ,Easier to answer with more Imfo.
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
I would lower it first. I find that if one of your options requires you to not drive your truck for a while. Especially when you really want to. That is probably the wiser option.
Thanks for the feedback guys.
I'm thinking 4" in the front and 6" in the back. Posted via Mobile Device
